The efffects of the Colonial pipeline shut down in Alabama brings up more questions than answers. Persons with knowledge in various disciplines may have answers.
Transportation
The effect of auto gas is already being shown here is Georgia as the discount stations are running out. Will this effect the auto travel on the I-85 corridor and I-95 Va north ?
Will this overload Amtrak on these corridors as Crescent south bound is almost sold out tonight ? Carolinian is not operating tomorrow for mtce. What is happening on the NEC ?
Since diesel and jet fuel is reduced as well will RRs need to bring in tank cars of diesel ? How does Amtrak handle that ?
Colonial has a direct pipelie to ATL airport. ATL airport is a major fueling point for all airlines. That can be mitigated somewhat by fueling as much as possible from non affected points to BHM, ATL, CLT, RDU, RIC, WASH, Unfortunately that might not be much help if airlines experience full aircraft.
Is there more standby storage in the NE than the south ? ATL storage location in Doraville appears to be maxed out and may be why running out of gas sooner ?
State of Ga. has suspended HOS for tanker drivers bringing in fuel from areas not affected.
What are other states affected doing ?
If this cotinues how quickly can RRs bring fuel to affected areas ?
How does this repair begin ?
Removal of spilled gasoline probably first as no welding until volitiles removed. How much has to be removed from idle pipeline ?
“There’s not much cheap gasoline, but there’s lots of expensive gasoline” (from the 1979 oil embargo).
Haven’t seen that up close, but have watched that done to natural gas lines (from a safe distance). Best is to install 2 other ‘tapping’ valves just each side to close off the line. If that can’t be done, a weld can be made as long as oxygen is excluded by a nitrogen, argon, or similar 'blankets. More likely is to cut a squared-off end and install a ‘plug’ with mechancial (bolted) joints at each end.
(kind of): As soon as I read about this, I thought this would be a good use for some of the idle CBR tank cars, to replace the pipeline’s function (although I see they are planning on building a ‘bypass’ pipeline around the break). Some temporary work-arounds (hoses, etc.) to load/ unload the cars at each end of the trip would be needed, but that might be faster than waiting for the repair, testing, investigations, etc. to be completed.
This lspill also casts doubt on the oft-heard claim that pipelines are safer/ less likely to leak than rairlcars. Estimated 336,000 gallons ~11 railcars. I believe that would a worse wreck than any since Lac Megantic. Worse, not detected for 3 days, and then only by chance by a nearby surface mine inspector !
Paul the 3 day reference read to ME, that it was 3 days AFTER the leak was DETECTED, before crews were allowed on site for repairs, due to high levels of gasoline and benzene vapors. I did not see any estimate of how long the leak spewed gasoline before detection, though that had to be quite a while to spill 336,000 gallons. Thank Heavens, there was no ignition source nearby.
Also right. How long was it going on ?? For a 3 ft. diam pipeline, it wouldn’t take long to leak that many gals. from the whole thing - 11 tank cars’ worth, say about 9 x that length of pipe for each car x 11 cars ~ 100 x 60’ ~ 6,000 ft.; at 1 MPH a little over 1 hr. But a leak that big would have caused a loss of pressure which the system sensors or operators would have noticed and automatically shut down. More likely it was a dribble to a ‘garden hose’ (as I like to describe moderate leaks or flows that are more than a drip and less than a fire hydrant), and could have taken several days.
They install blocking valves on both sides of the leak. It appears they also installed small hot tap valves adjacent for monitoring purposes. They have materials to deal with fumes to make it safe to weld. With the leak section blocked off, they then install a parallel bypass line. I would guess the line would be back in service in a few days, long before they could install rail load/unloading facilities. The bulk of the spill will be removed quickly, but it will might be years before the residual in soil/groundwater is cleaned-up.
The by-pass valves will finish being installed and in operation in one to 2 days ? The by-pass pipe finished about the same time. It would be very interesting how the valve is cut into the current pipeline. Colonial has no idea yet exact location of leak or cause ? Colonial reports 700+ persons working on the problem ?
More stations in Atlanta area are running out but so far motorists can get gas by 10 -20 minute waits at other stations. Our local Loves and its 16 pumps were all completely busy at 1415 today. Those pump positions do handle diesel. Gas prices = or about 5 cents less than diesel whereas usually about 40 cents less.
At a local station across from this poster was observed using a dip stick into its tank showing ~~ 14" of gas left. Reports that upper SC is running short now and wonder if that will proceed north east ward all way to NJ ?
One has to wonder if persons getting the last dregs of gas from a station might get fouled fuel filters or worse ?
The parallel pipeline is carrying some gasoline but appears it is smaller, slower, and needs more separation isolation work between gas and the diesel / jet fuel products.
You do not have the option of responsibly setting up a transfer, rail to truck or tank, overnite. Spill containment, track pans, grounded track, firefighting precautions, tank et al do not appear overnight. You have to permit yourselves to the slow as molasses regulatory system and work within PHMSA rules. by the time you got set-up, crisis over.
Would love to see when the last time the line was smart-pigged.
Well, close. A CAT with urinary-tract incompetence?
Here’s a dog-and-pony show that gets into some details of smart pigging halfway through:
Note that a considerable number of devices or ‘active protrusions’ can be combined in one ‘pig’, and it can be pulled by cable (and trail data cabling rather than use radio or onboard memory storage) rather than require pipeline pressure to push it.
