Nice. Depending on which conifers they are meant to represent, they look best as upright as possible, or curling over close to the top as a hemlock would. But, you have them placed naturally. I hope you enjoy them.
What awesome trees. You made them appear in a perfect spot. I’d prefer making them since I need more. It’s also more satsifying doing that. To each their own I suppose.
Actually, the bottle brush-type trees can be improved by some snip and hack work with scissors to make them a little less uniform-looking. I then spritz them with non-scented hairspray from a pump-type applicator, then sprinkle on some ground foam - use different colours and particle size as desired…
I wish I could find a few bigger ones.
I use mostly natural twigs and flowers as armatures for building trees, adding black or green polyfibre and multiple applications of hairspray and ground foam…
Lichen is useful for infill, too, and also benefits from the addition of some ground foam (not all of mine, as you can see, got that treatment.)
I think that hydrangea flowers, fresh or dried, with the petals removed, will make very good armatures for trees in open spaces (parks, residential streets, etc.), and may also be useful for creating a tree canopy where one needs to cover a larger area with forest. That could allow you to model full-trees only at the perimeter, with the majority of the coverage being simply tree-tops…perhaps almost as quick and easy as puffball background trees. These flowers have a very full array of small branchlets, providing lots of support for polyfibre and ground foam.
I tried to represent cedars planted as a hedgerow, using the flowers from a butterfly bush, covered with ground foam. They’ve been in place for a while now…
…close maybe, but not quite what I had envisioned.
I get my pine trees from the Philppines though e-bay, used to be sold by Tree-Dad but he is no more, still others sell the same trees. Very inexpencive and natural out of the box for the pine ones.
