A 32 oz bottle of Scenic Express ballast is about $12 - not a model train budget buster and will ballast quite a bit of track.
And here is the thing about beach sand (coming from a geologist by education/career). Even if you go to the trouble to get seives and “screen” it to get it the right size for your scale, and then get it dyed or colored appropriately, it still may not look right as beach sand tends to be rounded and railroad ballast is usually angular.
If appearance matters …
You won’t need a 50 lb bag unless you plan to fill an aircraft hanger with trains. I do hope you aren’t on such thin ice with your spouse that a bag of sand won’t push your marriage over the edge. [:O]
Back when I was a starving college student, I might have considered beach sand, but it seems otherwise there are better options. Your RR of course.
Bob Wundrock’s article in the Feb. '14 MR is “Expand a staging yard into the aisle”. The reference to using play sand for ballast is on page 70; and the 70% isopropyl is tinted with black leather dye. BTW, the track and ballast looks great!
If using beach sand, could it contain salt? Would this type of sand not be good to use on a layout? Salt draws moisture. I have shied away from using beach sand on my layout from my thinking, am I wrong in thinking this?
