New poles for prototype pole lines get delivered by NS on bulkhead flats to a team track area for the local utility. Makes for an interesting load and operation twist for modelers. Questioon though. How do you model something like that. That is not dead straight and tapers in some but not others. Any ideas i have been bouncing this around for a while
I use ⅛” dowels for residential power and rail communications for 35’ poles and 3/16” for 70” to 90” power poles. To get a taper I put the cut to length dowels in my bench drill press and run 100 grit sandpaper up and down the pole to get a slight taper then use a dark stain. I use .010” x 36” piano wire for wires. The piano wire doesn’t collect dust like thread and I can put the correct sag in the lines that stays put. I drill .010” holes in the poles and insert the wire to keep them in place. That way they can be easily removed for five finger maintenance in the area.
Mel
Have considered making some pole loads or piles awaiting distribution near the power plant. Like your idea for the wires Mel.
I have clamped my battery drill to my bench for several projects. Could use one or even a corded one to turn the dowels while sanding. (My drill press is a long way from the layout.)
I have a small odd shaped spot with odd requirements to make operation possible and clearences for arms and such to operate. Utility pole unloading is perfect for that spot, prototypical, and fits nicely with clearences.
