Hello All,
Thank you for all your great responses.
As I posted…
Unfortunately, the current replacement parts from Athearn are not a viable option.
Yes, I have three sets of them and nothing is compatible.
I apologize if I didn’t make it clear that I have two separate problems from two manufacturers:
The first is with Bachmann.
It’s the plastic coupler from the worm gear shaft(s) to the dog bone drive shaft(s) that has cracked.
This coupler is not available as a separate O.E.M. part.
Bachmann only sells this part in a larger sub-assembly, which is currently out of stock.
I only need this specific press-fit coupler, not the entire sub-assembly that I have harvested this specific part from, and have a surplus of un-needed gear towers.
The second is with Athearn.
Which is the plastic axel.
The older 42-inch wheels have a larger diameter spindle, that presses into the geared axel, than any currently available replacement parts, is cracked.
I have purchased several replacement wheelsets from Athearn and none of them fit- -adding to the useless parts bin, and lost monies.
This is why I am exploring the options of 3D printing these specific parts.
Thank you for this suggestion and I will look into this option.
[quote user=“snjroy”]
You might also want to consider NWSL. Given th
