Included this in my Free-moN module construction thread, but thought I’d post it here for the archives and to see how others do it:
http://youtu.be/7Tw56VcI56Q
I’m sure there’s better ways of doing it, but dang if this wasn’t simple and easy!
(Takes longer to watch the video than to do the dang project
And especially since Tomkat-13 has already put together and shared a KABILLION signs for us… there’s no excuse not to have some!
I make decals on my computer. It’s a relatively easy process. You can either use white-backed decal paper to get the colors right, or, as I do, use clear-backed decals and understand that the printer assumes you’re using white paper, so you need to provide a white background on the structure.
I find this works very well on brick walls, because the brick texture shows through and the sign takes on an instant weathered appearance. Here is a classic ad image I downloaded and made into a decal.
It does, however, illustrate a problem. I can’t draw a straight line, much less paint a clean, straight white rectangle on a building. So, you can see the uneven white border. Learning from my mistake, I now paint the white background a bit smaller than the image, and I use image-editing software to add a dark border to the decal, to cover up my uneven paint job.
This technique also works well on real wood surfaces.
