Postwar Lionel painting questions
I have a 675 steamer which I am restoring. It was covered with model paint and I have stripped it for repainting.
In a CTT article recently the author suggested using Krylon 1613. Is this considered ok for the average restoration? I am not trying to create a museum piece but do want it match my other lionel steamers.
The pilot and cyclinder pieces I have seen on other 675 engines look lighter , like they have a different fini***han the boiler. How were these parts finished and what products are available for that?
How do you strip the plastic tender body without damage. Can I use the same paint to refini***hat without damaging the plastic?
Whats the best way to fill small holes someone drilled in the pilot and boiler for the odd couplers they used?
Krylon semi-closs black is the most recommended paint and it works fine. I find it a little too glossy for old steamers and I use a flat black instead. I usually buff it out after curing to bring out some sheen. Lionel chemically blackend the pilot on most steamers instead of paint. I paint mine because the blacking process is hard to duplicate. I have had good luck using TSP cleaning powder (available at hardware stores) mixed with warm water to soak off paint on plastic bodies. It may take a few days but it doesn’t affect plastic. Bondo is probably the best thing to fill those holes in the pilot.
Neil
The current Floquil Engine Black is a pretty close match in sheen and will not hide the details like Krylon can. Old Floquil had a very flat finish. You can get it in a spray can if you don’t have an airbrush. You can also get a replacement pilot from the repro parts outfits which will have the cast in coupler that was removed by the previous owner.
Pete
The Floquil aqueous brand PolyScale Engine Black is also a good choice. It has an eggshell finish. Floquill is great but it is a solvent based paint (enamel), Both are best applied with an airbrush but you can probably get the enamel in a spray can. The plastic tenders I have/had were all made of black plastic. The only problem with refinishing some of these are the heat stamped lettering. The process of applying the lettering leaves a slight ridge around the edge of each letter. Micro fine sand paper can remove this and you can use extreme fine grades to poli***he plastic back to a smooth finish.
Krylon semi-flat black for the boiler, and black primer for the pilot. I have a repainted 2025 same as a 675, that’s been repainted this way. Looks brand new but not too glossy.
Jim
Thanks,
These are some good options. I got this in a suitcase full of old trains from a family member. I little clean up and repair should produce some good pieces for my collection.
I’m in Mass as well. If you ever want to get rid of those trains, let me know!
Jim
