Power and command
Power and command
i just purchased the cab1 command tmcc used system and have no idea of how to hook it up it came with the brick power house power supply and all the base and another base or something , any ideas on a wiring diagram?dont know if command control is for me never seen it in action i have a tmcc locomotive i just bought.
For the main question, I’d say add feeder wires spaced evenly around the layout.
Ralph, the components you have, are probably the Cab-1 remote, the TMCC Command Base, the TMCC powermaster (the second base you mentioned, which allows you to run conventional locomotives with the Cab-1), and the Power brick.
The brick should have a plug that fits into the powermaster, the powermaster has two posts on the back, one labeled A the other U, U is your ground and gets connected to the outside rail of the track, A is the hot which goes to the center rail of the track, from the post on the command base, you run a wire to the U post on the powermaster and the obvious seperate power supply for the command base gets plugged into the wall. This should help you out.
To: Bob
Can I make my own brick for the 64 watt MRC Throttlepack? I would like to make the 100 watt transformer in the 100 watt Thottlepack into a useful brick since it is too unpredictable for me. On its own it will creep or run at derail speed when I least expect it. I don’t want to waste the postage or service fee on having it looked at. It never was reliable from the day I got it. Instead of wasting money on it I just ordered a simple 64 watt Throttlepack. I figure I can just bring a connector lead directly from the 100 watt transformer case to attach to the 64 watt throttlepack control box. I assume the boost button is only for a limited time or you burn the box up? How many watts is the boost? Airplanes had a boost button for takeoff only or getting out of danger at the risk of blowing the engine.
I am just getting back into the hobby of toy trains. I purchased the Lionel
Canadian Maple Leaf set. Then I bought a Williams F3 A B B A Golden Memories with 7 passenger cars. The 80 watt transformer lacks the power to run the Williams trains. So I dug out my old kw transformer. It will run the
Williams. I’m a little scared to use the KW with the new Lionel. So I ordered the 270 watt MRC dual control transformer. Will everything be compatible? Will I be able to mix in MTH equipment too ?
