Yesterday a power line fell across CSX west of Rochester, NY delaying Maple Leaf and about 10+ CSX freights. Many trains detoured on the west shore line bypass,
The question becomes what the power companies and other utilities doing to mitigate the very high number of just reported Amtrak trains delayed due to power lines (probably other utilities as well) across tracks.
Here, at least in this part of Georgia both Georgia Power, the EMCs, ATT, and cable companies are all adding guy wires on poles on both sides of crossings that carry any of the mentioned lines over RRs, State / federal highways, creeks, rivers, & other utility lines to keep most lines from falling onto the mentioned locations. That is so poles do not fall toward the mentioned locations.
Now one problem is that if a wooden pole gets broken that will not prevent the fouling however, concrete or steel monopoles are being added at some locations already. For high voltage lines (69 - 169k volts or higher) either double concrete or truss types are added at these crossings.
Of course it is the home service primaries of 7200 V or 25 kV that can be the main problem. Especially the 25kV lines are very lethal but since they only started installing 25 kV somewhere between 5 - 8 years they are well protected by stronger poles and guy wires. Off topic find it interesting that new standard would be same as RR electrifications at 25 kV.
Have any of our posters noted that other states are having any of these protections added to greatly reduce this power line problem? If not maybe time to ask Pols and Utilities why not. Around here after 2 major storms there were not many reports of state / federal roads or RRs having been fouled by power / utility lines. Now residential / local roads a different matter with many lines down.
