Power routing turnouts?
I saw this mentioned a couple times in the, well it’s the most popular thread at the moment but for some reason I can’t remember the name.
This was mentioned a couple times and has peaked my interests, the elimination of blocks through power routing turnouts. Is this available for DC?
My layout wasn’t going to be anything to complex but turnouts would be plentiful, I know my Bachmann EZ track can perform this power routing. would it streamline and eliminate the amount of wiring from a layout or would it require extra wiring?
Thank you.
Gary,
From what you posted,about Bachmann E-Z track,on 5-10-2013,You said that the turnouts are junk…So I don’t know what to tell you,if you intend on using them…They would be unreliable,for use of power routing…
Cheers,
Frank
No, that’s not what I meant with this post I was using them as a reference when they do work. I was not intending on using them, I prefer Atlas track to other brands.
For my own sanity, I abandoned that thread a day or two ago, so I don’t know exactly what was said. But power routing turnouts do not eliminate the need for block wiring for multiple train independent DC control. They do allow you to park a loco on a track and turn the power off to the track by throwing the points of the turnout.
However that is not failsafe like a separate electrical switch to turn the power off in a block. If you happen to throw the switchpoints the wrong way, the parked engine starts up.
Better to wire the “parking” block separately (if all you want to do is park a train or engine). It’s very simple with an electrical switch, gaps, and feeders. I am sure that it is explained in one of your wiring books.
Or do the work to wire for true multiple cab DC, or go to DCC. Either of those would be much more flexible.
But it depends what you are trying to do, which still seems a bit opaque.
Ok, so it doesn’t mean I avoid an accident if I do hit the wrong switch. If blocks and multicabs would be far better for that then I can work with it.
I’m doing one train operation because I’m the only one who’s going to be running my layout 99% of the time. thank you for the clarification Alco.
BN24, Power routing turnouts are fine, as long as the track electrical power is only applied to the points end of the turnout. For instance, in the case of a stub-end siding. If you have a passing track, and fail to properly gap the turnouts, if you throw one mainline switch for the siding and fail to throw the other at precisely the same instant, you will cause a short circuit through the points of the other turnout. Power routing turnouts must be properly gapped and jumpered to avoid shorts. However, once you grasp the basic principles, it’s not a big deal. I use nothing but, but then I’m pretty old-school…
Hi gentlemen,
The above might help; however you can have power routed turnouts with and without an isolated frog.
Those shorts will occur when the frog is not isolated. When both turnouts are set to the siding the main will be off. Just forget one turnout when the frog is isolated and trains on both tracks will start to move.
Looking at the lower pic: when blocks are added you can completely turn off that piece of track. The power routing turnouts are now used for ease of switching. When a switcher is on block 2 and the turnout properly alined he can run onto the “joint block” without the need set the block in the proper position.
Without power routing turnouts you would need 5 blocks. Block 4 for holding a train, while the joint blocks are needed for switching moves.
Cab-Control-Wiring means every block can be connected to every throttle by means of an electrical switch. When more then one train is running at the same time it might result in focusing so much on those switches you forget to watch the trains. Two trains were still quite doable for me, more however took my fun away.
Still you can have only one engine in one block; think about picking up a few cars from the back of a train. Why is it so many are opting for DCC?
Paul
Gary,
Power routing turnouts are the time honored way to control dead end sidings or single ended yards, and it works just fine without having separate toggles for every siding. That said, using the points to transfer power can be unreliable.
It is much better to use extra contacts on switch machines or ground throws to direct the power.
As Paul explained they can also be used to reduce the number of blocks that need seperate control. Done properly it can cut the number of blocks that need to be assigned to your throttle in half.
I highly recommend you get Paul Mallery’s books - Electrical Handbook for Model Railroads - vol 1 & 2
http://carstensbookstore.com/elhaco.html
These books will explain all the various ways turnouts can direct power and reduce the number of electrical switches your control system will require.
Example - on my layout, complex double track interlockings route their power as needed simply based on the turnout position. This eliminates having extra blocks in those areas.
Here is picture of a control panel for a system I built for another modelers layout:
[URL=http://s1002.photobucket.com/user/carrollhome/media/DSC00249.jpg.html][IMG]http://i1002.photobucket.com/albums/af147/c
Paul,
You’ve introduced an example of operations here. I think this is usually a critical element of layout planning and is highly relevant to Gary’s question, or to others who may be at the same stage of planning. This might be an important area to explore in order for Gary, and others, to get a better understanding of the issues involved and the effort involved in going with power routing turnouts.
Paul, can you give Gary, and all readers, examples of operating scenarios whereby one locomotive is picking up a few cars from the back of a train? (I assume the lead locos are still coupled to the head)
Not that modelers want to necessarily adhere to any prototype practice, because it could be fun to do regardless, but why and where on the railroad would this typically take place in the prototype?
Gary;
Power routing turnouts are used with DC. Kato offers away on most of there switches to turn it off for DCC use.
Brian
LION does dew power routing. At end of line, the terminal receives its power from whichever main line track it is aligned to. If the inbound track is aligned for track 1, it is wired to the inbound track. Throw the switches and track 1 is now wired to the outbound track.
LION does NOT depend on the tracks to perform power routing, this is done either by the Tortoise switch machines (in simpler installations) or by a number of relays in more complicated situations.
LION has a small MOW yard behind the curtain wall at 34th Street. If either switch is aligned to the mainline track, the whole yard is connected to the main line track and receives northbound power. If both switches are aligned for the mainline as is the normal case, the yard is wired for south bound movement into one of three yard tracks. It sounds complicated, but it really is not. Route of LION does not have reversing switches or even throttles for that matter, so movement of trains is simply controlled by the switch levers on the interlocking machine. Rectifiers embedded in stub tracks stop movement in the correct place so that only an outbound alignment will move a train from the sidings.
LION also has one siding that will hold three trains. this one has a gang of three switches (on-off) for each position in the siding. A “Feather” along side of each position detects the presence of a train in that spot.
[ A feather is a long piece of soft smooth plastic that will encroach on the ROW and be pushed aside by a train occupying that location and activating a micro-switch.]
hmmmmm, that’s awesome lion. was there any extra wing or things done for this?
ooops didn’t read all of the replies above lions.
Power routing turnouts would eliminate blocks on certain sections of my layout because most sidings are going to be stubs.
I’m not sure if I will have any run around tracks. if I can fit any form of switchable industrie(s) on my layout the tracks will be dead ended.
Could power routing work for a turntable or will that have to be wired into three seperate blocks.
I saw DCC mentioned above I’m going to say this once for the sake of my sanity: Until it becomes a more financially viable option in both money and time for me I’m not switching.
This is not completely true. I did not get ANY shorts, and you do not have to throw both turnouts at the same time–it can work just fine with manually thrown turnouts.
All my turnouts are HO Kato power routing turnouts. I did have double ended passing sidings (prior to my current track plan), and I do not have any blocks on my modest layout, nor any toggle switches.
With power routing turnouts, at least the ones I have, if I throw a turnout to align a siding, if power is applied, then whatever is on that siding is going to start moving–whether I have the turnout on the other end of the siding closed or not–but there was no short.
My mainline power feeders are beyond the switchpoints of the power routing turnouts–so that if the turnouts are both closed, the siding is powered off by default. If even one turnout was open, then the siding is powered on.
One downside is the risk that if a train is running and you open a switch, another train may start running. This might be a hazard for some–I just prefer to think it
2 things I have learned from using power routing turnouts.
  1. It’s easy to get confused when wiring anything more complicated than a dead end spur.
  2. Using the points to carry the power will eventually fail.
My solution is to 1. use insulated rail joiners on both tracks on the diverging end (all 4 rails) just to be safe. Sure you can do less and have it work now, but what about when you add something later. 2. Use something other than the points to carry the current.
Enjoy
Paul
here we go:
In reality the road engine and the local switcher can divide the work.
After uncoupling the remainder of the train BEHIND the blue cars the road engine can spot these on track 4.
In the mean time, after picking up the caboose the switcher can spot the pink cars behind the last 3 yellow cars. The road engine returns to track 3 and couples all cars together. After testing the brakes it’s ready to leave, while the local switcher takes the blue cars from track 4 and spots them before their allocated industies.
Important however is the use of track 3. The left half is used by the road engine, the right half at the very same time by the local switcher. Hence track 3 should be divided into 2 separate blocks, just like track 4!
At your service
Paul
Paul, that was an Idea I was originally going to have for the layout, when the layout would’ve been BN. Looking over it now with the example, I’ll follow through on it because it’ll make operating easier. Thanks Paul!
Paul,
As usual, your illustrations are excellent and are worth thousands of words.
And in your example, the switching district is large enough to warrant its own separate switcher.
Ok, so I have an ME #5 RH turnout. I found out that it’s power routing, but(there’s always a but) My locomotives die once they reach the other side of the frog. even with the track terminals literally joining the turnout to another piece of track.
Gary,
If in fact,that the turnout,is power routing,you have just found out,why everyone,has been saying,that point pick-up for power is unreliable… Try it again,if it does it again,take a small screw driver and hold the points against the rail,if that does not work,you have a different problem…
Good Luck,
Frank
