Any specific suggestions for purchasing a power supply for Lionel FasTrack Power Block Lock-on?
Lionel says you can use the option of fixed power (from a barrel jack connector) via a separate sale 4A 18UDC power supply. Need to make sure anything I buy has the correct barrel jack connector. I tried to plug in an old 18.5v 6a laptop power supply but the jack was too big. I tried another power supply but the jack was too small.
I purchased two new Illuminated Lionel Stations, 684318, and hooked them up to the Power Block track using track power. But I am running post war trains (Conventional?) and the lights in the station are very dim. I assume they were designed for 18v dc and work best with that.
Also, does anyone know why Lionel recommends 4a? If I am just hooking up accessories with LED lighting can I make do with less than 4a as long as its 18v dc?
Appreciate any help / suggestions.
Thanks
