I have short wheelbase steamers and want to power the frogs of my “DCC Friendly” Walthers/Shinohara code 83 turnouts. There doesn’t seem to be any provision by the manufacturer to do this. Do you have any siggestions as to a simple method?
Regerds,
BB
When I first saw this title, I just had to laugh - if you aren’t a model railroader, it must sound bizarre - like we’re resurrecting the original galvanic experiment, or something.
Got your attention didn’t it?
BB
There is a website - recently posted - re: wiring the new Walthers ‘DCC friendly’ turnout’s.
Orher than that , drill a small hole (.080-.090?) or cup in the underside of the frog, install a matching brass screw, solder a fine brass wire , and clip off the excess screw, leaving the wire and it’s post…
A ‘Divot’ can be made in the roadbed to accomdate the ‘post’ remnants of the screw.
Bruce,
I soldered directly to the bottom of the frog after cutting away the plastic. Made this modification to about 5 of the Walthers switches.
Sorry I am still learning…what is a frog?
It is an amphibian…just kidding. In english it is the part of the switch where the rails cross each other, and it has the small section of rail head missing so that the flange can pass through.
This Frog is no more it has ceased to be.
The frog’s not dead it’s just resting.
Mate, this frog wouldn’t “voom” if you put four million volts through it!
‘E’s bleedin’ demised!
'E’s passed on!
This frog is no more!
He has ceased to be!
'E’s expired and gone to meet 'is maker!
'E’s a stiff!
Bereft of life, 'e rests in peace!
'Is metabolic processes are now 'istory!
'E’s off the twig!
'E’s kicked the bucket, 'e’s shuffled off ‘is mortal coil, run down the curtain and joined the bleedin’ choir invisibile!! THIS IS AN EX-FROG!!
Sorry, just had to look it up…
Brian Pickering
[:D]
Monty Python rules.
Finlay: the frog is the place where two rails cross in a switch or crossing.
I think the name comes from a part on the hoof of horse – check it in a dictionary or ask your horse-mad sister.
It looks like this ><
[:D]
Generally, I send my dead frogs to Madame Gadreaubeaux in N’orleans for a little voodoo when its time to repower them. [:D]
