Does it require 4 Tortoises to power a double crossover?
Or, can it be done with fewer, say one or two Tortoises?
Thanks
Thanks
A crossover only has 2 valid settings - both routes cross over, or both routes go straight. You can do it with one Tortoise and a lot of linkage, or two and a little less. Depends on how mechanically inclined you are to make up the required linakge, and if it’s worth your time to save the cost of 2 or 3 extra Tortoises. With 2 Tortoises, each one operates a pair of diagonally opposite turnouts in the crossover.
Randy,
Thanks.
I would like to do it with 2 Tortoises to save $30 to $40 in new Tortoise purchases.
Do you, or anyone else, have any information or drawings on what kind of linkage would be required to accomplish this with 2 Tortoises?
Google “tortoise double crossover”, there are MANY ways to do it.
http://model-railroad-hobbyist.com/node/3480
are a couple.
you can see what I did here. I made a linkage similar to how the tortoise works. it mounts like a tortoise and connects directly to the tortoise for movement. I used two tortoises to power the whole thing. i created two of these linkages.
Thanks everyone for your help on this issue.
After carefully reviewing the ways to limit the number of Tortoises required to power a double crossover, I have decided to spend the $30 or so to buy two more Tortoises to go with the two Tortoises that I already have available.
I am not mechanically inclined, at least not to the extent necessary to build the necessary linkage to make this work with only two Tortoises.
You can however still wire all 4 up to one DPDT toggle so you only need one switch to set things for straight or crossing over. If one runs the wrong way, just reverse the connections on pins 1 and 8.
Randy,
Good point. You are right.
I do have a double crossover on my layout already, powered by four Tortoises [:(] , and a single DPDT switch controls the movement of the entire double crossover. As you point out, why not, there is only one passage route at a time on a divergent route on a double crossover.
i really like Renegade1c’s ‘brio’ tortoise [:D]
Brio Tortoise! Come to think of it it does look like one.
It doesn’t really take a lot of mechanical ability. Just the ability to bend piano wire into cranks. Use a brass tube through the roadbed as the pivot point.
I drew this for someone on the forum a few years back with the same question.
Here is an picture of a different brand of slow motion machine controlling two points simultaneously. This happens to be both turnouts on one side of a double crossover, but the concept is identical.
