I’ve never found any need to do this UV exposure routine.
It can’t hurt though, as long as you aren’t setting it in the sun (or lamps) where temperatures get to the point where the acrylic can soften, and don’t leave the model out there long enough for the parts to begin yellowing. I don’t believe it adds any value, however.
If you are watching the Shapeways forum, you may see some users experiencing “powder on the surface” of some FUD or FXD models. I have never seen this after hundreds of models, so I believe it is either from inadequate cleaning- perhaps oil crystalizing over time or wax particles.
Notably, several of the UV post- curing advocates claim to have powder appearing. Perhaps their feeling that post-curing is needed is actually a reaction to a poorly cleaned model.
Inidentally, if a model arrives warped, this is from the cleaning mineral oil being a bit too hot at the factory. The part can easily be straightened by holding it in very warm water- about the temperature where it feels hot but you can still hold it without discomfort- for a minute, until it softens slightly. You can then, after making sure it has softened, gently straighten it (just like a resin part). An electric blow hair dryer can be used for this as well.
Have fun with your models!
Steve
[quote user=“HO-Velo”]
Steve Hunter
Simple Green
Thanks Steve, I just happen to have a jug of Simple Green on hand.
That is exciting news about possible ready-to-paint FUD.
Do you feel it prudent to expose Shapeways FUD parts to UV light before cleaning & painting to insure resins are fully cured? And if so would sunlight do?
Thanks again and regards, Peter
