Problem with Programming Track
I have a DCS 210+ that will not recognize the program track. Every loco I put on the track, I get a “program track is empty”. I am using a separated programming track wired per the Digitrax instructions. No matter what I do, it will not read, a decoder, or anllow me to write or change CV’s. Any ideas of what could be causing this.
Thanks
I would check with Digitrax-Users@groups.io.
From Google:
Fixing DCS 210+ “Program Track Empty” Error
If your Digitrax DCS 210+ shows “program track is empty” when you try to read or write CVs, it usually means the system isn’t detecting a valid programming track connection. This can be caused by wiring issues, incorrect setup, or hardware faults.
1. Confirm Programming Track Setup
  • Isolate the programming track from your main layout. It must be electrically separate from the rest of the rails Digitrax.
  • Connect it directly to the PROG A and PROG B terminals on the DCS 210+ (or DT602 controller) Groups.io.
  • Ensure both rails of the programming track are connected and insulated from the main layout.
  • Power the track with the DCS in RUN mode, not OPS mode Groups.io.
2. Check Wiring and Connections
  • Verify that the wires from the programming track are securely connected to the correct sockets on the DCS 210+.
  • Use a decoder tester board (e.g., ESU) to check if the PROG A/B lines are sending/receiving signals RMweb.
  • If you get the same “empty” error with a different decoder on the tester, the fault is likely in the DCS 210+ or its wiring.
3. Test with a Known Good Decoder
  • Place a decoder that you know works on the programming track and try reading its CVs.
  • If it works, the issue is with your original decoder or its wiring.
  • If it also fails, the problem is likely in the DCS 210+ or its internal programming track circuitry RMweb.
4. Check for Runaway Motor Issues
  • Some users report that when the programming track is faulty, the motor in the decoder runs uncontrollably until power is cut RMweb.
  • This can happen if the PROG A/B lines are shorted or have incorrect voltage.
  • Ensure the programming track voltage matches the DCS 210+’s requirements (usually 12–15V DC).
5. Firmware and Hardware Checks
  • Update the DCS 210+ firmware to the latest version from Digitrax.
  • If the problem persists after testing, contact Digitrax support or your dealer. A faulty DCS 210+ can cause persistent “program track empty” errors RMweb.
6. Quick Troubleshooting Steps
  1. Disconnect all track wiring except PROG A/B.
  2. Power the DCS 210+ and connect a known good decoder to PROG A/B.
  3. Try reading its CVs in service mode.
  4. If it works, recheck your original decoder and wiring.
  5. If it still fails, suspect DCS 210+ hardware.
Tip: Always power the programming track from the DCS 210+ itself, not from a separate power supply, to ensure correct voltage and signal integrity Digitrax.
By isolating the programming track, verifying wiring, and testing with known-good components, you can usually pinpoint whether the fault is in the decoder, wiring, or the DCS 210+ itself.
Read less
