I just had 2 of my new steamers professionally installed with the new Titan decoders.
I just got them back this week. So last night I started with the Athearn 4-8-4 UP 844.
After spending over 3 hours last night fighting with it, I was ready to smash everything to bits.
I’m using the latest version of Decoder Pro. And I selected the Titan Steam decoder.
Where to begin, oooh…
OK first the loco would barely move, all jerkey. Ok fine, adjust the start voltage. I spent over an hour just trying to figure out how to get it to not jerk. The start voltage is set at 75. BEMF was also causing problems, it was enabled by default. I had to change it to Standard Throttle Control.
OK great, now it doesn’t jerk. On to the sound. First of all, there are WAAAAAAAY to many options. There must be like over 200 options just for sound. It has dual speakers, and you can adjust each sound for each speaker. Way too complicated.
I was having problems with the Chuf sounds. After programming so many times, the decoder just started acting really wacky, the Chuf sounds were getting garbled.
At one point it sounded OK, but after running around the layout, it started acting wacky again. And then it started jerking again. I ended up resetting back to defaults.
After a reset it, it was fine, so then I started changing the sounds again. Back to the garbled sounds.
I reset again, and this time nothing worked, no movement, no sound. Reset 3 more times. Finally it’s alive again. I was able to get rid of the jerking, and the sounds were finally right.
I don’t know if this thing is faulty or what. But I don’t like it at all. At this point, if anything changes with jerkeyness and/or chuf sounds, I will have to get the decoder removed and sent back.
I didn’t even start on the other loco, it’s an EM-1. I’ll let you guys know if I have problems with that.
Bottom line, newly designed decoder is buggy.
