A few questions for you. Is the Digitrax decoder you installed a board decoder? Or, did you remove the lightboard that came with the SD45 to install the Digitrax decoder?
If the original bulbs were incandescent then they might have been 1.5V bulbs. If you removed the lightboard then you would have removed the built-in resistors that came with the lightboard; allowing the use of the lower voltage bulbs. If that were the case then they would have received 12V or higher and blown instantly.
Which Digitrax decoder did you install? Assuming it doesn’t have built-in resistors, you will need at least a 1KΩ (1,000 ohm) resistor if you want to install 3V LEDs. And I would go with a “bridge white” 3mm LED for a SD45.
Does the SD45 have a lightpipe? Or was the incandescent bulb inside the lens of the headlight?
And it does confirm that they came with 1.5V incandescent bulbs. Given the photo of where the original bulbs are located, a 3mm LED should fit right into that same trough. And a piece of Kapton tape will hold it in place just fine.
I believe I removed the board. They blew pretty much as soon as it turned on, flashed once really bright.
I cant remeber the decoder I bought. I will take a picture of it later. It looks like an RC car battery. Has a wrapped portion with 10 wires coming out ( 8 going to the * pin harness and 2 for other functions)
And I believe the 45 has light tubes but unsure. I took the shell off and the bulbs were on the frame not the shell
Your description of a blown incandescent bulb is spot on. Don’t ask me how I know.
Yes, you would need a resistor on one leg of the LED. I would suggest a 1K ohm, 1/4 watt resistor. I mention 1/4 watt because a 1/4 watt resistor is smaller than a 1/2 watt resistor and takes up less space under the shell.
You should use heat shrink tubing on both legs of the LED and cover the resistor with heat shrink tubing in the process to prevent any possibility of shorting the LED.
I use clear caulk to glue LED’s in place. Some people use CA to glue them to light pipes.
LED’s have a polarity that needs to be respected, if you want light out of them. I can never remember which lead is which, so I keep a picture of an LED and the color codes for DCC wire (which I also can’t remember)
The longer lead on the LED is positive (+). It should get the resistor. One other way to identify the positive side of the LED is to look inside the casing and find the smaller piece of metal which is the positive side. The positive side of the LED connects to the function output tab on the decoder that controls FL/F0 on the function key on the throttle. It is typically associated with the white wire on the decoder.
The shorter lead on the LED is negative (-). One other way to identify the negative side of the LED is to look inside the casing and find the larger piece of metal which is the negative side. The negative side of the LED connects to the COMMON tab on the decoder, and it is typically associated with the blue wire on the decoder.
Temporarily taped in place. I sometimes use “Sticky-Dots” to hold them. this stuff can be repositioned or easily removed. Technically it is called fugitive glue.
I’ve always found this diagram helpful for identifying the various parts of an LED:
In reality it doesn’t matter which lead of the LED you solder the resistor to. However, I would pick one as your standard for consistency. If you should ever end up trimming both LED leads shorter to make the LED fit the space requirements of the shell or the chassis, it will make identifying the cathode (-) side of the LED quicker visually.
Personally I find it easier to use black heat shrink as the interface between the LED bulb and the lightpipe. Otherwise, you have to flatten the ends of the LED and the lightpipe with a file to maximize the surface area for gluing.
The black heat shrink also helps to minimize any extraneous light from being cast inside the shell area. That probably won’t be an issue with Ringo’s SD45 but would be for an LED in the cab area of a small switcher or an F-unit.
It also makes LED replacement much quicker and easier. Yes, LEDs are supposed to last “forever”. However, they can and do burn out.
