Does anyone have any information on the Pennsylvania Railroad interlocking tower NY in Portage PA. I am trying to find information so I can write and article about it in my museums newsletter.
I’m not sure but is this what you are looking for? (I’m so sorry I don’t know how to create links[:(])
I would join the Yahoo group PRR-Fax that has some people that eat, breathe and sleep PRR. If they can’t help you it doesn’t exist
NY Tower, unlike others in the area had an unusal non-area designation which stood for New York Tower. MO in nearby Cresson for example stood for MOuntain, SO for SOuth Fork, why the NY was determined. Research I have done on the Portage area indicated that NY tower had three different locations the final built in 1891 at MP 259.1 just west of Portage. This was located on the south side of the mainline near where the Bens Creek Branch connected to the mainline and several crossover tracks directly in front of the tower.
It was a two story wood structure, typical of PRR appearance, the upper level had five windows facing the tracks, two windows on the sides. The lower level had three windows trackside. The tower was built on a cement basement elevating it to track level. This slight elevation was due to the fill used to reroute the mainline through Portage creating a more consistent grade and straighter line to Cassandra. This massive project done c.1899. The Bens Creek Branch (through Sonman) is the original 1854 mainline.
NY’s original area of control was from Wilmore MP261 to an area near Cassandra MP256 and was expanded to MP 254 when LY Tower in Lilly was eliminated in 1931. This area of control included the Wilmore track pans, four passenger stations, Cassandra slide detectors, storage tracks near the tower, and branch lines serving the coal mines in the area. The signal bridge at MP 259.37 had water spouts attached for steam locomotives, near the the tower were four water supply tubs a water tower on the branch line (Bens Creek) and just east of the tower a water spout.
Its final mechanics were a P-5 type modified electr-mechanical switch machine. It had seven levers for signals, nine for switches and two for traffic, eighteen on a twenty three lever frame.
The tower was manned for twenty four hours per day,
I belong to the Portage Museum but I could not find much information on the tower there and I want to do an article in the newsletter there and make a display about it. I heard from someone that the tower was destroyed by a coal train that derailed and crashed into it. Do you no if this is true? If not do you no its demise?
NY was taken down by the PRR because it was no longer needed. A derailment is what cause a signal bridge near NY to be taken down, this occured long after the tower was removed.
Charles Edwards who helped build the train display at the museum is my married to my Mom’s sister. He may be able to help you with some info on NY.
Also as a side note, the tower signs are still around. One is in Texas and the other is owned by a gentleman in Cincinnati OH.
I am the person that helps Charles at the museum. One time I asked him and he said he did not know much about NY but he knew alot about SO since he grew up in South Fork. I heard from a few people that next year or the year after that they will be tearing down MG, AR, and ALTO.
Austin
Is it possible that NY comes from the last two letters of Allegheny? Here is a link to an unofficial NS timetable for the route. Scroll down to page 4.
Hey BT,
Thats a theory that I have heard before and it does have some merit. I checked into documents on file in Altoona and with the PRRT&HS and could not verify such. For some odd reason as far back as the 1800’s it was refered to by the railroad as New York Tower. Many of the PRR early documents were destroyed in that shed fire in Philly, so much info was lost.
The location of the tower was near the base of the western rise to the summit. The mainline climb eastward started in Portage coming through the flat Conemaugh valley area from Johnstown. I feel this is the one possibility that makes sense, although I am still searching for confirmation. Who knows, maybe someday I will strike gold and solve the mystery.
Thanks!!
There’s a little bit about NY on a couple pages (only !) in the late Charles S. Roberts’ history of that line, PRR - Triumph I: Altoona - Pitcairn, 1846 - 1996 - see:
http://www.barnardroberts.com/bookdescriptions.html#book1
A lot of the names and other features of that area were tied into or based on the Portage Railroad and the inclined planes, etc., which of course preceded the PRR there. Perhaps something in that led to the NY ? Otherwise, I’d bet a lot more on the AllegheNY theory than the New York basis - heck, at that time the PRR didn’t even have a line across the Hudson River into Manhattan, NYC. So there was just no ‘nexus’ with that - may as well have named it MN for MooN !
- Paul North.
Hi Paul,
The old Portage Railroad was another idea I had when researching the area for any clues, nothing. Other than Portage being the “main yard” for the APRR not much relating to road was discovered. My family is from Portage and I have spent many years trying to dig up so much lost information about the railroad in the area. As I stated earlier the Allegheny theory is a good one, but when recording history best evidence is a must. And why the New York reference for so many years?
As to Mr. Roberts book Triumph 1, very poorly researched and way too many assumptions with little factual backing. Enjoy the book for its pictures, as to text , beware. Book reviews in the PRRT&HS Keystone were not very supportive of it either.
K4sPRR - Gotcha, on all counts - good insights, too. I know the feeling . . .
I hadn’t heard or read that about Roberts, but I’m not surprised. Comparing what he wrote and obsessed about with some aspects that I know . . . well, more information is always better - and it is more interesting than ‘dull as ditchwater’ prose - but I’ll take the primary sources at face value, and what he wrote with a ‘grain of salt’.
For what it’s worth, I looked in that volume earlier this evening and there is a poor-quality photo labeled as being NY Tower in a circa 1918 valuation photo at the bottom left of page 197, together with about 8 lines of sketchy caption. NY also shows up in a few other scattered places - mostly just shown on track charts or other maps, not in the text - such as on pages 167, 168, 189 (in the caption under the map of LY), 190 (bottom), and 191 (top).
- Paul North.
I found the picture attached of NY tower. (which is not the best of quality). It must be of either the first or second location (If I had to guess it would be the second.)
I was talking to a historian on local railroad history, and he was telling me that no one really knows the exact story of how it got its name and back then for some areas they just assigned two letters.
http://portagepa.us/gallery/nytower.gif
Austin
Hi Austin,
You are correct that photo is the second location for the tower, originally it was further west toward Wilmore. A photo of the original location is in the book “On The Mainline”. As to the picture you posted that tower was later rebuilt and it remained until it was dismantled in the 1960’s.
Every tower on the mountain had a designation associated with the area, this NY thing has been a challenge.
Dan
Is it possible the interlocking at Portage was older than the two east of it, and NY tower controlled the tracks to a junction with the Cresson & Clearfield County and New York Short Route Railroad?
http://query.nytimes.com/mem/archive-free/pdf?res=FB0D1EF6345F10728DDDA90B94D9405B8684F0D3
Mike
I think that 30 mile line is now the Irvona branch for RJ Corman. If that is the case, then the NYSRR did not come close to Portage.
Of course a friend of mine did mention that most of the original interlocking and tower names that had letter designations are a mystery to most and have not clue where they come from. For all we know the people responsible for “naming” the interlocking just heard about the NYSRR and said “lets just call it NY, it will do.”
[quote user=“wanswheel”]
Hi Mike,
The two towers east, LY (Lilly) and MO (Cresson) were around when NY originated, LY at about the same time and MO was much earlier, it dates back to the 1850’s when the line was originally built. NY never had a range of control that went that far east, even when LY closed in 1931. The original NY was a combination depot/tower that was located in an area along S Railroad St. in Portage. Its only concern were nearby sidings, two of which on the north and south side of the then two track mainline that served coal mines to the west near Wilmore. These sidings gave a portion of the original mainline a four track appearance, saved some time for the four track rebuild in the 1890’s.
I liked your posting of the NY Times article, just shows the importance of railroads way back then, who today would imagine a part of Clearfield Cluster having an article in a New York paper. Interesting post, thanks.
Dan
Dan,
Isn’t the photo in the book “On the Mainline” of the second tower? I thought the last tower was the one attached below:
Austin
Hi Austin,
Correct, the tower in the book is the second one, it was later relocated and moved to the location in your photo. The tower in your photo was the third.
Dan
