A few years ago, Centralia Car Shops came out with some beautiful models of the PRR P-85 coaches. Unfortunately, everything seems to have been glued together. Has anyone found a way to get into the interior of these cars without destroying the model??
I am bumping this very old thread because I’ve got the same question now in 2019. Does anyone know how to open up the Centralia PRR P85b coaches without risking destroying then? Thanks.
I have never found a way of opening these cars to access the interior. I was also reluctant to push my luck for fear of destroying the cars.
Is Centralia still in business? They initially offered these cars as kits. Last I heard they were releasing N scale cars through Intermountain’s distribution network.
I was curious myself so I contemplated a method of attack. You are correct, everything is glued together. With a little bending, tapping and squeezing I determined that the roof was indeed cemented on but only at the ends and center.
Fortunately, the openings through the car-ends are open enough to poke a long-shank, flat blade screw driver in and pry up on the inside of the roof. The end of the screwdriver winds up about a third of the way in and this is just the place where the roof wasn’t glued:
With a little careful prying, and a little pressure on the car sides the glue bond eventually comes apart. Try each end a little at-a-time, one end may be glued better than the other. I dislodged one of the end walls at one end (easily re-glued).
