I recently installed a new LED light on a locomotive. I need to mount it in the cab. I want to know if it is safe to glue the bulb to he headlight lenses using CA glue or is there another way to accomplish this task. Thanks for your help in advance.
I’ve used CA or regular super glue for gluing my LEDs to all kinds of goodies for years without a single problem including headlight lenses and light pipes.
Mel
With all due respect to Mel, I would NOT glue an LED directly to any lens or light pipe with CA. If and when the LED burns out, it will make it much more difficult to remove it without breaking the lens.
Is the lens flat, or is it connected to a light pipe? If the latter you can use 1/8" OD black heat shrink to make the connection between the two. The heat shrink will also help concentrate the beam through the light pipe and less around the interior of the cab.
If the lens is flat I would recommend gluing a short (1/2" long) piece of 5/32" OD/1/8" ID styrene tubing to the lens. This is what I used to add a rear headlight to a Walthers SW1 a few years ago:
I’ve been very lucky and never had an LED headlight fail, but I have changed the LEDs. A sharp pair of wire cutters will separate the LEDs from the lens without dinging the lens, flat edge toward the lens.
Mel
Ed your right, in thinking back I remember having some AC ding some clear Styrene. About 7 or 8 years ago I switched from the hobby type AC to Harbor Freight Super Glue in the .10 ounce tubes and I’ve never had a problem with it. I switched because of the small tubes not because it was any better, just easier to use in the tiny tube and when it dries up over time I’ve only lost less than .1 ounce not a half bottle of CA.
I have used the Testors version of Canopy Glue as well as clear silicone caulk. Both are easily removed and both hold good enough. Neither dry as quick as CA but I’m in not rush.
