Why is the hollow core door so popular for the smaller layouts ? Why not just buy a 4/8 sheet of plywood for a fraction of the cost, and rip it to the same dimensions (width-wise; you could keep the extra 16" length on a plywood sheet if desired) as a door if needed ?
Mailman,
I’m not an N scaler, but as a woodworker I can give you why I would choose a door over just a piece of plywood. The door, even if it’s a hollow core door, is built as a torsion box when laid flat and will remain much flatter and truer than just a piece of plywood without any supporting framework attached. If you take a piece of plywood and build a supporting frame for it, you’ve just built the same thing as the door without the second skin installed. A 36" wide slab door is $32.00 at Lowes, about the same for a 3/4" sheet of plywood.
Don Z.
Ah, thanks, I see.
p.s. Boy, judging by the various prices I’ve seen listed, I’ve got it made [:)] 3/4 plywood here is $13 a sheet (local lumber yards), and chipboard is $10.
Foam is cheap too.
$13 for a 3/4" thick piece of 4x8 plywood? Where do you live, 1983???
Seriously, that’s an EXCELLENT price for plywood, which averages $35 for 3/4" in the Chicago area (for BC grade!). I can’t even get 2" thick foam for that cheap, and the stuff is made 50 miles from where I live! I’d stock up if I were you!
Small town, Northern Minnesota [:)] Few weeks ago, the Lowes (or was it Menards ? Can’t remember…) at Grand Forks, ND had a huge stack of 1/2 for $10 a sheet.
Mailman,
You can also score a door like I did, for free, from a crew that was remodeling a house. I was walking by it (it’s down the street from me) and the door was just leaning against a pile of debris. I asked what they wanted for it and they told me to take if I wanted it.
Now, it had a hole where the doorknob was, and where the hunges were, but what the hey… free is free.
I also have scored a fair amount of lumber, lathing and foam insulation from various construction sites. Same with plywood sheeting. They use a fair amount for various jobs that just get tossed afterwards, and much of it can be salvaged. Just ask to speak to the forum, tell him what you’re doing (building a model railroad for your kid… right?) and ask if you can have any of the scraps. I’ve never ben refused as long as i could carry it off with me. Never hurts to ask, and can really help the project bottom line, you know?
Respects,
Mailman,
Respects,
Yep, agreed, great way to get various materials, thanks !
