Assume a railroad mainline runs from “A” through “B” to “C”. At B, a small branchline diverges and runs several miles to a mining town at D.
A
B ---- D
C
How would passengers typically be routed to D? Would their car(s) be shunted onto a separate branch line train? Would they disembark and board new cars that remain captive on the branch? Or (unlikely I think) would the entire train traverse the branch line, turn at D, return to B and then continue on its way on the mainline? There are probably examples of each, but which would be the most common?
I’m reminded of a ‘modern-day’ version of this. On the Pennsy and later in Penn Central years the ‘dinky’ ran from Princeton Junction on the NY-DC main line and it went to the small station at Princeton University.
From what I ‘ve read regarding the early 1900s, the branch, B-D, would have its own “captive” passenger cars, possibly of older stock, and often running in a mixed train.
Cheers, the Bear.
Ed, whatever happened to the Dinky? I remember about twelve(?) years ago we had a big discussion about plans to discontinue it, but I don’t remember hearing anything about the final outcome. (I doubt our discussion had any influence on the final decision.)
At certain times of the day a train could run A to B to D. Such trains would be passengers who work at the mine, or freight trains.
Here in the U.K. (in rural Northumberland) D became far more important town than C. Therefore the route had more trains running. Trains between B & C only ran twice a day.
From what I gather NJ Transit is still running it. Seems like Princeton University keeps moving the station farther away from campus, I’m sure for the interest of customer satisfaction!
The method of operation that a carrier would adopt would probably depend on economic and operational criteria, such as:
How long is the branch, and how many intermediate stations does it contain?
How big is the branch terminus?
What kind of facilities does it have?
Does the branch generate a lot of travel for one terminal or the other?
Depending on the answers to these questions, railroads had a lot of options. If the branch was small and lightly traveled, it might just get a mixed train, scheduled to connect more-or-less punctually at the junction with service between the two main terminals.
If it was larger, that train might be a scheduled passenger train, operating the length of the branch, and connecting with an express. If it were larger still, and needed more service, the express might drop a “section” (possibly including a Pullman sleeper) that would either operate up the branch as a separate train or connect to the branch line service. If the branch rates a truly important service, it would be a destination in its own right, served by a dedicated train from one (or both) terminal points. Sections might also include mail and express, which could necessitate some interesting switching at the junction.
The operational variety and potential are significant, as is the potential equipment variety.
It still runs, with some flavor of Silverliner. New Jersey Transit cut the line back a few hundred feet, about even with New South, and built an enormous station facility. The old station building never did get its bronze entrance repaired; it was a trendy coffee and pastry shop the last time I was there. Regretfully the WaWa that used to be there is gone.
When I got there in fall '75 the pair of MP54s was still running, with Buster timing with his Metroliner-spec Accutron. I was down train watching on the main and happened to see the set – one in PC green, one in Tuscan — as it was going south after being retired; they had it up over 60mph, the afternoon light shining, the gears singing, off to Valhalla. I never saw an MP54 running after that.
If I remember correctly the Faculty Road grade crossing was the site of the last train robbery from horseback in the United States.
I always thought it was because it was a ‘little train’ that met all the bigger trains like the Toonerville Trolley.
For what it may be worth, in the grim and thankfully long-gone years when college freshmen had to wear ‘beanies’, the headgear was referred to as ‘dinkies’. My father, who matriculated in 1945, would change the subject quickly if you asked what freshman year with the hated beanies was like.
I suspect the beanie deal ended very shortly thereafter, when the students started to come in under the G.I. Bill. If a battle-hardened Marine didn’t want to wear a beanie, I don’t think most upper-classmen would bother to “correct” him.
How busy is A to C in terms of passenger traffic?
How busy is the branch line to D?
How far is B to D?
How far is A or C to B?
If A to C is already a pretty sleepy route, and B to D is not that far, a single train will just run up to D as part of its journey from A to C.
If the distances are all pretty far and/or A to C is a pretty busy passenger line, there might just be a short connecting train that meets mainline trains at the junction.
If B to D is a reasonable distance, but B is close to either A or C, a branchline train might run out of one of those terminals to D and back.
You can definitely find examples of all of these - I can even name one of each off the top of my head.
