I admit to having very little knowledge when it comes to wiring. Yet I have a large task ahead in wiring my post war layout.
When complete, it will have four main lines and a trolley line. In total, there are twenty-one blocks, eighteen post war switches, eight uncoupling/operating track sections, a zillion lighted structures, and a few accessories.
I am using two post war ZW’s for train operation and had planned to used a Model Z for powering the switches, building lights and accessories.
Thus war, I have jimmied up various portions of the wiring project and now am attempting to make these more finished.
I am consolidating everything at a central point and have modified a bookcase with pegboard as a back panel to bring all of the wiring into the case. I am using terminal blocks to bring everything to a common point and running power to these blocks.
I set out to perform what I thought would be an easy task by running power to a group of five switches.
Using the original switch plugs to bypass track power, I connected four switches to one terminal block and then ran one wire from the block to the model Z transformer. Result = no power to the switches.
I tried the A, B, C, and D terminals with the same result.
I ran the same wire to an unused terminal of the ZW (B) and the switches are powered and work great.
Figuring it is unlikely the Model Z is bad, I tried to power the track from the Model Z. It worked fine on all terminals - A, B, C and D. Yet it will not provide power to the switches.
Is there something I don’t know, or are the train Gods just messing with me?
