Rail Flange-way Grade Crossing Road Hazard Reduction
As we have seen, there is a road hazard to smaller vehicles if their wheels are suddenly caught in deep railroad grade crossing flangeways. Crossing longevity design calls for best possible drainage. Flangeways are also susceptible to colleting freezing water that then builds up ice all through the flangeways. Such ice fouling of the flangeways can derail a train. Apparently this collection of ice and other debris is the reason why flangeways are often as deep as possible. The depth gives more volume capacity to hold the buildup of fouling materials to delay the onset of actual fouling of the flanges.
The totally safe grade crossing flangeway would be normally totally flush with the rail head surface as though there were no flangeway at all. Then with the passage of a train, the material fouling the flanges would be flexible and be compressed by each flange to accommodate the interference of each passing flange.
I do not find any product that completely fills the flangeway to make a totally flush installation. Maybe that has been tried, but never perfected. The probable principle of such a product would be like this Epflex Railseal, but with no open flangeway at all. Then the flexibility of the filler material would allow it to compress under each flange, and then rebound after the wheel passes.
I assume that developing this principle with the proper elastomer material and extrusion configuration would be a nearly insurmountable challenge. The repeated working of the material by deflecting under each passing wheel flange, under a variety of weather conditions, would tend to wear th
Positive Wheelchair & Bicycle Control
As one who has “lost it” riding a bike across a RR crossing I learned that eeven if you think the angle between road and railroad is close enough to 90 degrees to be safe, it is best to angle your route across in a way to make it 90 degrees, not just close to that, at least when it is wet. Dry conditions allow more latitude but any crossing that requires you to turn your head enough to be uncomfortable needs to be taken with extreme caution. Asphalt rash may not be quite as bad as gravel rash, but it still hurts. (And I was young when this happened, don’t want to try it with old bones now)
PR
The issue of vehicles vs flangeways goes back to the era of horse drawn street cars. Back then, most vehicles had wooden wheels with strap iron tires which led to many cases of wheels getting caught in the flangeways. A couple of the compromises included tram rail and grooved rail, though most street railways preferred to use T rail when they could (talking electrified street railways).
I’m of the opinion that any vehicle intended for use on public streets or sidewalks either needs to be designed to accommodate flangeways or being placarded against crossing RR tracks.
I’d like to see testing of the flangeway protection technologies to show that they do not increase the chances of a derailment.
The mindset of the ADA is that failure to accomodate the needs of the disabled, violates their constitutional rights.
Now a huge factor to be taken into consideration is the concept of “technical feasibility”. If it is determined that full compliance is not technically feasible, then exceptions can be granted. provided that all other aspects which are feasible, are met.
Googling “ADA Technically Feasible” will reveal that this is one area that has received a LOT of creative thought, at least in non-rail applications.
I’d guess that with truck hunting, as well as various weather conditions and how they might affect a mechanical flangeway device, there might be some room for negotiation there. JMHO
I don’t see why flange fillers should cause a derailment risk. They only have to be stiff enough to hold maybe 150 pounds of wheel weight, but not so stiff that they fail to give way for a freight car wheel flange. That is a mighty big window. Why does the filler function have to get anywhere close to being able to derail a train?
For some reason, they are deemed acceptable for LRT, but not for heavy rail lines. So given that conflict, plus the inexplicable worry about derailments, I would conclude that the real reason for holding back is the operating life of the flangeway filler.
I suspect that prototyping and testing has used flangeway fillers that are way overrated for the pedestrian, bicycle, and wheelchair function out of an abundance of caution. Then these stiff fillers wear relatively quickly. In the transit application, there are likely fewer wheels per day than on freight lines. Perhaps the tendency is then to make the fillers even more robust and stiff to the point where derailment concerns begin to rise when coupled with cold weather and ice buildup.
There may be a design sweet spot that has been missed in this development. The parameters would be the number of wheels per day, the travel speed of the wheels, the type of material, the cost of material, the expected operating life, the weather conditions, and cost of replacing the fillers.
I beleive the operative term is “reasonable accomodation”. Forbidding narrow wheel wheelchairs does not prevent a disabled person from crossing the RR tracks with a wheelchair equipped with sufficiently wide wheels. Putting it another way, it was not the railroad’s fault that the wheelchair was not designed to deal with flangeways.
Well, I’m not looking for a fight, but I’d be very surprised if the authorities where that charitable.
They aren’t going to prohibit “unsuitable” wheelchairs from certain routes, imo.
Other than “umbrella strollers” most wheeled conveyances have wheels large enough to cross the tracks at right angles. The question with this particular incident is how/why he got turned so his wheel(s) could drop into the flangeway.
Also unanswered is how often he, and others like him, use this crossing.
Which then begs the question - is there really a problem here that needs to be solved?
The voice-over on that video sounds like Morgan Freeman!
Sincerely, I don’t know what ails our society. Nobody seems capable of taking responsibility for their own actions…every little slight that befalls them, the blame has got to be bumped “up stream”. Usually targeting any deep pocket that can even tangentially be tied to it.
If I was riding a bicycle and my wheel sank into a flange way, or a storm sewer grate,(provided they were structurally sound, and not deteriorated/neglected) and I took a header…I would be embarrassed over my own stupidity, I’d likely look around hoping no one had seen me, and I would move on. But I seem to be in a slim minority there.
Unfortunately, I expect someone will adopt this event as a cause they must champion. And ride it for all they can manage. I could be wrong, but I smell an “overkill” remedy in the making.
Personally, I could live with a “cross at your own peril” sign. But a “Wheelchairs with thin wheels not permitted” sign…not so much. I don’t think that the “barrier-free” folks will swallow that one.
That’s obvious enough almost to require no answer – someone almost died. And for precisely the sort of short sight in design engineering that calls for elimination of defects.
The principal reason to combine this with ‘crossing’ improvement at all is that there are other crossing users also affected by flangeway issues, almost all of whom have those issues addressed with something as simple as Euclid’s relatively low-compression-force filler approach. But it is more than a little specious to bundle a tiny critical ADA remediation in with much greater public benefit as an ‘unfunded mandate’ or even a funded one that imposes even a chance of contributory liability.
Leaving aside the issue charlie hebdo raised about railroads being ‘better citizens’ with crossing and other concerns, I continue to think that the remediation force should lie squarely on the scooter ‘infrastructure’ and their various insurers, and that while remediation kits’ for narrow casters and inadequate road wheels might not be mandatory for all users they should be required just as in a mandatory automotive recall – new slightly-smaller caster wheels on either side of the existing one, in an appropriate frame and bearings, being a completely appropriate solution that solves among other things the whole of the jamming issue with flangeways and does so without making others bear the brunt of the mistakes. And while there’ certainly a place for a Lorenzo Coffin of open flange gaps, I’d prefer activist ‘laser focus’ on fixing deadly scooter defects first and foremost.
Is it an engineering defect if someone uses the product improperly?
Why was his scooter in a position that it could drop a wheel in the flangeway? The road crosses the tracks at very nearly ninety degrees. He could have been across the tracks and in the clear in ten or fifteen seconds.
Thousands of people cross tracks on similar installations every day. With no ill effects. What made this one different? Would flange guards have actually made a difference?
“Used the product improperly?” Wow!
You seriously think that trying to turn around because a train is coming at you typically leads to some sort of carefully weighed decision? Probably the man was scared ****less and thought turning around was his best option for survival. He was wrong but I am sure he did not have the time or ability to estimate the railgap width and compare that with his scooter tire widths, which he would have memorized, of course.
I think flange fillers could have prevented the hangup. Total flush flange fillers seem to be in use, but also limited in some ways. But the main issue is the width and depth of the flangeway. The values of width and depth for best train operation seem to be inconflict with the values of those who must cross the flangeway gap.
What pressure level should the ‘flange filler’ respond to? A sideways ‘scooter’ dropping one wheel into the ‘flangeway’ can develop a reasonably high pressure level when you consider a 100-200 pound ‘scooter’
Let’s go back to the videotape (actually Google Street view): https://goo.gl/maps/7dEEfyp9ryPnt6oA8
Wide open view in both directions for at least a half mile. If the train was doing 30, he had a full minute to make his crossing from that half mile point. If you look at a map of the area, that section of track is arrow straight for a good mile in either direction. Even if the train was doing 60, he still had that minute to get across from the time he could first see headlights.
The crossing gates are required to be down for 15-20 seconds before a train enters the crossing. From the first ping of the bell (at 30 MPH) he had about a half a minute to get across, if he decided to make a run for it. Or to get off the crossing if he was already on it. He didn’t need to turn around. There is plenty of room to clear the tracks before one runs into the mis-located crossing protection equipment.
You clearly do not understand the effect of negative emotions, particularly fear, on people. Perhaps you cannot put yourself in another’s shoes. Some people flee, while some freeze. Calculations of distance and speed and how much time remains are easy sitting at home, not for a man who probably has become quite fear prone because of being in a wheelchair or scooter, a sense of helplessness.
And this is why I ask - was this a regular trip for him, or the first time on this route? If it was a regular trip, maybe he got complacent and started across without thoroughly checking for trains. Perhaps he has cognitive issues.
Maybe he’s gotten stuck there before but never encountered a train before someone helped him out of his predicament.
We have no idea how long he was stuck before the officer spotted him.
Too many unaswered questions.
There are two separate issues here. One is whether the rider violated the crossing laws such as entering after the lights and gates activated. The other is whether he entered with the crossing warning un-activated, but did something that contributed to the incident.
The second issue is in a gray area because even if he did something that contributed to the incident, that does not necessarily make it his fault. If somebody leaves a manhole cover open and unprotected, and somebody falls into it, who do you think will be most negligent? Just because a victim could have done something that would have prevented an accident, does not necessarily mean that it was completely their fault.
In the case of this crossing, I think it is a stretch to conclude that the person in the wheelchair is at fault because he turned parallel to the rail. It is unreasonable to conclude that he should have detected this hazard. Wheelchairs are made to be highly maneuverable. They are zero-turn steering and able to pivot on a point. If a user comes to an obstacle, it is perfectly natural to turn the chair.
What is unnatural is to blame him because he should have realized that turning would trap a wheel in a deep and wide slot cut through the pathway. You cannot leave a booby trap and then blame the victim for not avoiding it.
