Hi Folks over the pond can some one tell me when they where first used, Having just returned from your neck of the woods I would like a date as differant people over there gave an assortment of dates[:)]
Are you asking about the 'Crossbuck"
or the “crossing sign”?
I was able to locate a patent for the crossing sign dated 1923. Was not able to locate much info as to date of the crossbuck. I could be very wrong on this guess but I’m sure that the crossbuck predates to yellow crossing sign by many years. I was able to locate a Louisiana state regulation that required the crossbuck to be at a height of nine feet so as to be easily seen when driving horse drawn wagons and buggies. That regulation was dated 1887. I hope this helps answer your question.
Crossing signs have been used since the beginning, as as was everything else at the time, it was done according to the local railroads needs.
The earliest mention of standardization I can find was an article from the New York times dated July 27, 1919 that set the signs as “a circular metal disk, 34 inches in diameter with a white field and a black border line 1” wide and with black perpendicular and horizontal cross lines 2 1/2 inches wide with a black letter “B” 5 inches high in each of the upper corners. It is to be installed on each side of the crossing at a distance of not less than 300 feet."
