i got a q. for anyone is good on ho gauge. me and my son were running all the engines that we got and came across a f3 engine that has a rappid click when its running wheels are smooth on the track no jumping at all and its comming from the engine inside what can i/we do to get it to stop thanks chad from pittsburgh pa. at the trainstation/home
I think you have something rubbing against one of the internal gears. It may be a piece of plastic, a wire, a retaining clip improperly seated, or maybe even a split gear…it happens.
Sounds like you have a cracked gear. Who is the locomotive manufacturer? Some of them have noted problems with gears cracking and may send you a replacement set free of charge. If not free, they are relatively inexpensive. Remove the shell, then run is slowly to determine which truck it’s coming from.
Some of the early production Life Like Proto 2000 (P2K) and Proto 1000 engines, including the Proto 1000 F-3, had a problem with the gears splitting – and the result was exactly the sort of clicking that you describe. It does not alas get better.
Fortunately Walthers, which now owns Life-Like, has recently re-stocked a supply of replacement wheels with gears on the axles that are intended to be used with, among other things, the F-3. Assuming that is the make of F-3 that you have, you may want to ask your dealer to order this for you:
For Early PROTO 2000(R) BL, FA, E8, GP7/9/18/20/30/60 & PROTO 1000™ F3
Walthers Part # 920-584408
HO scale, $5.98, currently in stock at Walthers
Take a look at the picture on the Walthers website and see if that doesn’t look like your wheels
