As one of my New Year’s resolutions, I vowed to get some work on the Crocodile done…
(for previous pic, see: http://cs.trains.com/ctt/f/95/t/225848.aspx )
In order to install the trolley poles and pantograph, the roof headlights and air tanks had to go, alas. Dremel + saw blade = lotsa sawdust:
Helpful Hobby Hint: Those cheap plastic signs at Walleyworld make a great source of inexpensive sheet styrene:
Some sanding later:
A bit of putty to fill in the holes:
Plastruct roofwalks cover a multitude of sins:
Test fitting the pantograph (the “insulators” are brass threaded inserts salvaged from barcode scanners):
