Recently a very good RCS customer here in Australia asked me to convert an LGB Mikado to battery R/C.
Part of the specs were that he wanted to retain the excellent LGB sound and the way that it worked such as the two toots of the whistle for forwards and three for reverse. Plus he wanted to have the RCS sound trigger functions also work the regular reed switch triggers.
It actually took two attempts to get the installation right.
The first time it all went together just fine with all the equipment in the boiler and the batteries in the tender.
Problem was the range at about 20’ was not very good.
To solve the range problem I had my customer return the loco for modification. I removed the RF-RX part and antenna from the boiler where the LGB sound was causing RF Interference and relocated them to the tender shell. This solved the problem and the range is now over 100’.
Some of the pics were taken during the first version so do not show the modifications to RCS components in the boiler.
This was the very first time I had seen an LGB Mikado so the the hardest part of the conversion was figuring out how to get the loco apart. With a little help from Dave Goodson I soon had that problem solved.
The first part of this “How I did it” are a series of pics with arrows pointing out which screws need to be removed.
I recommend placing the loco upside down in the top of the foam packing. This will help protect the loco from any damage during handling.
Pic #1 is self explanatory.
Pic #2 (a & b) likewise. Sorry they are bit out of focus.
Once the motor block assembly has been removed refer to pic #3.
[img]http://www.rcs-rc.com/pics/LGB-Mikado/03
