Re-motoring a Rivarossi 2-8-8-2 Mallet
I’m just getting back into model railroading after about fourty years. My (now deceased) father and I built a 12’ X 16’ layout which he tore down before he died (I was busy working and he didn’t know how to run the layout so it got in his way).
I’ve since built a 9’ X 12’ layout (which I have since found out is not the ideal setup but that’s another issue).
I tested all of the locomotives which were all in disrepair but ran EXCEPT the Rivarossi 2-8-8-2 Mallet. The motor brushes were worn out and the motor smells awful. I’m assuming that the motor is toast. I found a proceedure at Northwest Short Line that describes remotoring it using their #18337-9 motor and u-joints #488-6. I have a lathe/milling machine so modifiying the frame is not an issue.
Has anyone done this? Did you use the NWSL parts or did you find another source that worked better?
Any and all information will be greatly appreciated.
I did a remotor and universal job a few years back and now can’t remember what all i did. I also ground down the flanges. On that one, I simply powered up the loco while spinning a dremel grinder against the drivers. Took my time and it seemed to work OK. The loco worked fairly well after all that but the guy i di the job for had trouble with it. I think though that his trouble was caused by too much handling of the loco.These photos may help. BILL
Thanks for the reply.
I finally figured out where the “search” funciton was here (right hand side of the screen – I’m used to having it at the top of the screen on a tool bar). Found a ton if information (along with the picture you posted of your feet! LOL!–I do the same thing!).
More information on the loco: It is a PRR #2197. Walthers has the part number for the NWSL motor but they’re sold out although they list a hobby shop in PA that supposidly has it in stock.
Beyond all of this, I also saw in the search here that someone put a motor like this: http://www.wholesaletrains.com/Detail.asp?ID=200415453 in there. This motor is in my GP40’s that I have three of and they run smooth, quiet and have plenty of HP. We have to visit my wife’s store in Big Flats and Lantz Hobby is right on the way. That way I can look at the motor before buying it.
The plan is to build a Erie Lackawanna layout with diesel power. WHY I’m rebuilding the Mallet is beyond me other than it has sentimental value. Dad loved seeing the steam engines run. He was an avid baseball player and hit the longest home run in history. He hit a ball into a gondola on the O&W and that ball is still traveling to this day! LOL!
It appears that NWSL may not be making the 18x33 flat can motor anymore, along with the rest of the Sagamis. My Tiger Valley ALCO RSD-12 diesel is powered by one of them, and I’ve found it to be no better than a decent motor. It runs smooth enough, but it’s kind of noisy, and I had to adjust the brush tension for better running.
It’s a little more expensive, but I’d recommend the 18x33mm flat can motor offered by A Line. It’s the same size as the NWSL motor (except the shafts, which are 0.4mm smaller), but I’ve found it to be a much better one. It works at the same speed, draws half the electrical current, runs a bit smoother, and is quieter at all speeds. You’d just have to get 4826 universals from NWSL for the smaller shaft size (Rivarossi’s shafts are about 2.1mm, so it may be an easier conversion than with parts for 2.4mm shafts). NWSL’s universals are the best around, so I’d stick with them for things like that.
These are the motors currently used in all Athearn Genesis diesels, and they are excellent runners. They would also be a good choice for repowering, but they’re also 3-4mm longer than the NWSL and A Line motors. They may still fit, but it’s something to keep in mind (they also have a 2mm shaft like the A Line motor). You’d have to pull the flywheels off, because they would make it too long (NWSL makes a tool for pulling wheels, flywheels, etc.).
If you do a search on Ebay for Rivarossi Parts you should find a dealer named “backshops”
he has some very good replacement motors that are low draw and perfect for DCC conversions
I bought one from him when repowering my F-19 Pacific
Love It
Thanks to all for the information. This is again confirming that the internet is for something other than porn! LOL!
I’m going to pull the cab off one of my GP’s to see how big the motor is so that I don’t back myself into a corner with buying one only to find out it won’t fit.
Once this one is done, I have two other steamers that I’d like to upgrade. One is a 2-8-2 OLD Bachman and the other is a 0-6-0 that I built from a kit. The 0-6-0 is a puzzlement too as I can’t remember what brand it is. I thought it was a Bowser but they say it isn’t one of theirs.
I remotored my Y6b with a CD tray motor that I pulled out of an old disk drive, and in combination with a pair of NWSL reduction kits for the upper gearboxes, it has more than enough torque. This is a much less radical (not to mention cheaper) option if you don’t want to mill a well for a can motor out of the boiler weight.
Mine is an earlier version with a ball bearing motor, but it was off-balance enough to be noisy with the reduction kits. Rivarossi motors aren’t the greatest, but they’re very durable; come to think of it, I’ve never seen one burn out. It may need nothing more than brushes and a good commutator cleaning. Very often motors that smell like they have burned windings are suffering from nothing more than a buildup of brush dust and oil.
The old Bachmann Consolidation is more of a challenge, since they have that annoying pancake drive. They can perform nicely if well maintained, but the noise will drive you batty. Bowser used to make a replacement frame & drive for the Bachmann 4-8-4’s, but I don’t think anything was ever offered for the 2-8-0.
whatever you do don’t take the Rivarossi motor apart,There’s a dozen or so ballbearings in there that will fall out and noway to put them back. There must be a trick to it as they put em in there when they build the things.
Also I read a letter somewhere on line by the current owner of NWSL, that Sagami motors are no longer made or at least not made the same way…
That’s only true for the older square ball bearing motors, of course, which are instantly recognizable by the hex adjusting screw between the brushes. Also, being open frame, they will lose a majority of their magnetism if the armature is removed from the field. On an Italian Rivarossi forum they actually recommend using lard in the bearing cups to keep the balls in position and away from the magnets during reassembly. [C=:-)] [dinner]
It’s safe to take their round motors apart.
Reassembling a Rivarossi ball-bearing motor is tedious work, but it can be done. For the upper bearings (6 BBs), I put just a little Vaseline in the BB race, take a tiny, slightly magnetic flat-blade screwdriver, and position each BB in the race with something non-magnetic. The lower bearing (11 or 13 BBs, depending on the motor) is a little easier, using a similar method. And if you lose magnetism, take out the old magnet, cut a little of the plastic frame out, and put a stack of 5 1/2"x1/4"x1/8" neodymium magnets in place of the old one. (scroll down a few posts in this topic to see what I’m talking about).
The Rivarossi can motors are easier to work on, and with a little adjustment they’re fantastic runners. Practically new motors can be found on eBay fairly often.
I really don’t think it was meant for that in the first place.[xx(]
Bowser used to make a full repower kit for the 2-8-0 (the 2-8-2 is the 2-8-0 with a rear truck). Looking at the old diagram, it may also be possible to fit a small CD drive motor in there. I could be wrong, though.
What does the 0-6-0 look like? There have been quite a few 0-6-0 kits available from manufacturers like MDC and Mantua/Tyco. Bowser’s only 0-6-0 was released only a few years ago.
Genius,pure Genius, The lard in the bearing trick. Only thing is I was unaware they were there at all when I took the motor apart and at least half of them disappeared into that place where all things are invisible.[:(]
As for losing the magnetism??? Another magic trick by the manufacturers. Who thinks this stuff up?[D)]
Speaking of invisible things, I dropped a journal spring from a disconnect truck on the floor, smooth concrete, I couldn’t see it at all but when I got down on my hands and knees I just happened to put my finger tips right on it. Sometims I have good luck. I try to keep the floor under my bench clean for that very reason. BILL
I’ll take some pics of all of the steam locos and post them as soon as I get time.
I don’t know about any of you, but building ANYTHING from a kit is the best part of any hobby (RC airplanes, trains, cars, etc.).
No kidding… don’t sneeze. [:O] Labor must have been cheap in Italy back then.
The alnico magnets in open frame motors needed a magnetism boost from a big coil once the motor was assembled, but it’s lost when the field (magnet, pole pieces, & armature) is disassembled. Ceramic and the new neodymium magnets don’t need the extra charge.
As promised pictures of the 0-6-0 and the 2-8-2. They are dusty from sitting for YEARS. The 2-8-2 had to have the cab replaced as dad dropped it somehow and broke it hence no numbes on the cab.
We lost Sagami from the Kobi, Japan earthquake. The factory was destroyed and the family decided to retire instead of rebuilding. It was a shame, they made a very good can motor. Mashima and Cannon area also excellent can motors. My guess is if you clean and put new brushes, 1 carbon and 1 mesh, in that motor, it will run fine. If its the round metal motor, they can be taken appart, not the easiest thing to do, but it can be done. The guy on ebay offers a tape recorder drive motor that fits inside the gutted motor case of that round motor. Also an excellent option to get one running again. Cheers Mike
Ok, those are both Mantua/Tyco steam engines. They can be upgraded very easily using the remotor kits from www.yardbirdtrains.com (D8120 for most, or D8124 if your 2-8-2 has the gearbox design). Or you can put a 1/2" neodymium cube magnet in place of the weaker one in the old motor, like I did in the topic I posted a link to earlier.
Gosh, I thought the 2-8-2 was a Bachman but I could be wrong.
As for the 0-6-0, it was a fun kit and runs well although a little noisy. It will pull about a dozen + cars on flat track which I find amazing for such a small locomotive.
Here’s Bachmann’s original 2-8-2: http://www.ho-scaletrains.net/bachmannhoscalelocomotives/id56.html . It’s simply their 2-8-0 with a rear truck slapped on. The only other one they’ve made in HO is their Spectrum Chinese Mikado in Susquehanna, which looks like this: http://www.walthers.com/exec/productinfo/160-83212 .
Here are a few pages showing the Mantua/Tyco 2-8-2:
http://tycotrain.tripod.com/redboxerasteamengines/id7.html
http://tycotrain.tripod.com/steamengines/id4.html
http://i143.photobucket.com/albums/r132/tonycook1966/Mantua%2078/78_06_Mantua.jpg
http://i143.photobucket.com/albums/r132/tonycook1966/Mantua%202001/12_2001_Mantua.jpg
It sure had a long life! Mantua made them until they went out of business in 2001. Model Power bought what was left of them, and has continued the Mantua name since.
