I have a built Campbell coaling tower to install. Problem is I get one shot as the back of the building has a large bin that goes into the deck so foam decking must be cut out. Need distance from building to first rail. Also how close can the water tower be and the sand house. On approch it will be water tower, coaling, then sand bin for sand tower. Running older stuff so don’t need clearance for double stacks etc. LOL.
The distance from building to center of track would probably be around 13-15 feet.
The best way to figure it out would probably be to set a section of track on a table, then position the tower so that the chute will be in the center of the track when in the loading position. Then just measure from the rail to the building and - poof! - there’s your answer!
To each other or the track? Here is a photo that shows placement in relation to each other, though there are no hard and fast rules about that.
Just thinking out loud for another solution. If the final result is that the tower will abutt the second tier decking with the bin concealed by the surrounding decking so that its unseen, could you just leave off the bucket and simply abutt the unbucketed tower against the uninvaded decking? Might be simpler with the same basic result.
The PO does not mention a second tier.
There are some pictures of the backside of the structure here
At Chama the sand house is right next to the coal tower, the water tower is 100 yards down the line.
I would cut out more of the foam than necessary, and then fill in the gaps with scrap foam once you’ve settled on the position.
This could be a guide:
coal_wood by Edmund, on Flickr
However, there are always compromises when it comes to scaling dimensions to the model. Use an NMRA gauge.
Good Luck, Ed
I am thinking 9 1/2’ from first rail to building. 18’ from building to sand bin and 21’ or so on other side to water tank (ladder sticks out that side).
Water tower? Stand pipes could be placed on both sides of the coaling chute if non directional. One way lines the water stand would be on the end opposite of the coal chute or first in line. The sand house can also be placed in another spot and piping system would feed sand boxes.
Just keep the ash pit far enough away from the coaling station. That coal dust was explosive if ignited.
Pete
The real problem is the coal chute being fixed except for the extention.
I had the same questions with my Kanamodel water tower. I had my yard tracks, where the tower was goint to be, partially sunken into dirt/muck. If I had placed the tower out on the mains, I would have had to elevate it substantially due to the elevation imparted to the ties and rails by the raised roadbed and ballast depth. So, I initially thought that I would just have to figure out how close to the rails and plunk it. Not so, Grasshopper. I still had to fashion long sills for the support posts to get the whole tower and spout high enough to look like it would dip at a sufficient grade to allow water to flow quickly during a fill of a tender’s cistern.
Once I got the height right, the rest was simply eyeballing how close to the tracks the spout pivot and chain/cable counterweight assembly ought to be to look reasonably accurate. It ended up a lot closer than I had guessed. The diagramme provided above says 8’ from lower slide pivot to the center of track.
Luckily the Campbell water tank I built high enough that that isn’t a problem and I also have the Campbell sanding tower, some of the first kits I ever built but I could not do any better today.
