I’ve wanted to jump in to garden railroading since '98 when I saw the EPCOT layout! I’m finally gonna do it…
From what I’ve read here, I think I want a rechargeable battery-powered R/C locomotive. Does any manufacturer make a good start-up kit, or do I have to convert a traditional ‘power-via-rails’ system? What do you guys recommend?
I’m brandnew at the forum and I’m writing from Germany, so my recommendation may base on other circumstances than large US-trains require. But as I understand american model railroads I assume you operate long and heavy trains. In this case a rechargebable battery powered locomotive equipment is disadvantage compared to rail powered systems. Locomotives loaded with long trains may not remain long on their battery power. On the contrary I would recommend a DCC system with an appropriate booster, for example 10 or 20 Amps. Operating such a system requires clean wheel sets and also clean rail heads but will bring you satisfying play sessions.
By the way: The best option for outside rails are stainless steel ones. Even nickel-silver rails will work much better than brass ones.
People often seem to assume that “remote control” means “battery power.” But you can run remote control with track power–I do it all the time, running four different locos at once. I’ve been using Aristocraft’s 75 mhz onboard system. With most Aristo locos, you just plug the onboard receiver unit into a socket on the loco’s circuit board, sync it up, and off you go. It takes more time to get the loco shell of than it does to install the board.
It works extremely well for me but I have a small-medium size layout. for larger layouts there may be range issues
Aristo is going to abandon the 75 mhz system, though, and is supposedly coming out wth a new system.
You can also do track power and remote control with QSI’s new bpard, which has the great advantage of having sound built in. In that case you need to use the Airwire throttle system. But the QSI onboard receiver plugs directly into the aristo circuit board
Long trains–US proto-types–Lighted passenger cars–consume lots of power=use track power=use stainless steel track=alot less cleaning=A Happy Railroading Experience…Yes it has been considered before…Ask Marty C.
Track vs battery is a just a huge debate. Both have advatages
My layout is not too big, has a steep grade in it and my wife and I like to run long passenger trains lit up at night. That’s a good argument for track power. A smaller track is easy to clean, and steep grades and lights draw more power from your batteries. If I had a bigger layout with less grades and didn’t run at nght, battery would maybe look more attractive.
I wish I’d started with stainles steel track–just less cleaning required. Track cleaning with brass track isn’t that big a deal, but I have to do it pretty much every time I run using an aristo track cleaning car or a drywall pole sander. It’s not that big a deal but it would be nice not to have to do it.
I’ve been away from the forum working thru our spring rush…sorry to not post a ‘thank you’ for these responses.
My family operates a feed 'n seed, hardware, and garden center in northern New York. I’m having to remove a display pond/waterfall from the nursery yard and I want to put the railway in its place. Not to be a dealer, but to increase customer traffic in the garden center. (And have a lot of fun.) Getting power to the track is no problem, so electrified stainless rails I guess is the way to go. And since it would run for the public all day, it sounds like battery power wouldn’t get the job done.
I’m awfully impatient to get started, but my summer is disappearing fast and I gotta get the pond out of the way first. Then I plan to go to a large-scale store in Burlington, ON and see what they can sell me. Any other bits of advice would be greatly appreciated.
West Nile - I’d have to go along with what altterain (Brian) posted. I just started with battery RC this year. I bought the following:
Aristo-craft Battery Car (part no. CRE 55497),
Aristo-craft Lithium Ion Battery (part no. CRE 55610 - make sure you buy a battery that has just been manufactured in May or June of this year - there are a bunch that arrived in March that won’t work with the Battery Car),
the special Li-Ion battery charger (CRE 55620).
Any one of Aristocraft’s newer diesel engines (RS-3, GP40, SD series, etc). Not sure about their steam models (anyone know?).
You also need an Aristocraft Train Engineer Transmitter (CRE 55473).
Yes this setup will cost you several hundred $$. The advantage - you do not require any tools or installation of any kind. This is 100% Plug and Play.
Charge up the battery (approx. 4 hours), place it inside of the battery car (thru the door opening) and plug it into the wiring harness.
Synchronize the Transmitter with the Receiver (instructions w/ transmitter or battery car show how that’s done).
Set the locomotive’s Track/Battery switch to “Battery” (located underneath a top cover on the engine).
Plug the Battery Car’s “mu” plug (hangs out by the coupler) into the locomotove’s matching “mu” plug.
I just got the battery a few weeks ago (one I bought in March was defective) and I have never run it longer than 1/2 hour since. But I have put it away and come back a few days later, run it for another 1/2 hour or so, put it away again, and done this like 3 times. The battery still has a charge and I haven’t detected any loss in voltage (as “measured” by train speed and brightness of lights. Bottom line is - I really don’t yet know how long it takes to run it down! [:D]
I should note that I use either an Aristo RS-3 diesel or a GP40 diesel - both have two motors.
However, comments from various veterans of Aristo battery setups (similar to mine) that I have read on other forums indicate that 4 hours should not be a problem at all provided you start with a fresh charge, you aren’t trying to pull too many cars, you don’t have steep grades, and the loco does not have it’s smoke unit turned on. As always - your results may vary depending on the locomotive specs and all the other factors above.
I’M LOOKING ALSO. Ii’M NEW TO GARDEN railroading and I can’t find any advertised manufatures selling battery power locos. CONVERSIONS ARE $800+
What I have found was a cheap bATERY POWER, REMOTE CONTROL SET SOLD BY SCIENTIFIC TOY AND PURCHASED AT KB TOY STORE IN A LOCAL MALL AROUND XMAS TIME .
THE SET SOLD FOR LESS THAN $50 . ALTHOUGH NOT ACCURATE TO PROTOYPES. IT WAS A 2-6-0 WITH 3 CARS. AND PLASTIC TRACK. IT RUNS PRETTY WELL, IS FAIRLY RELIABLE AND DIDN’T COST $800 (OR MORE)
I ACTUALLY PREFER IT TO MY ELECTRIC BACHMAN AND ACCUCRAFT LOCO’S AS MY GRANDKIDS PLAY WITH THEM( SCIENTIFIC) AND I’M NOT CONCERNED IF ANYTHING IS DAMAGED
