I just wanted to say that this Circuitron product is great. An excellent engineering job that works as well as I could have hoped for. I needed it to control a turnout where cutting away the obstructing benchwork was not an option. As this was my first one, it took a while to complete the installation, but the instructions are well written with good illustrations. Once installed, it works as well as any of my direct connect Tortoise machines.
I may need a few for my yard. Glad they worked well for you. Unfortunately, they seem to be on order with an unknown delivery date at Walthers and are listed as out of stock in all other places I have looked. Anyone know where they might be instock?
I think Litchfield station has them and at a good price too!
“Currently out of stock”… Probably the boat won’t set sail til after the games are over… (Big Grin)
Thanks anyway.
Agree completely. My first Tortoise installation was a remote install because of hidden staging directly under the turnout; the instructions were lengthy, but the steps were so simple that they took longer to read than to actually accomplish. Operation is very smooth and reliable.
Chris
http://www.trainsetsonly.com/page/TSO/CTGY/SWMACH
Try Train Sets Only. Currently shown as In Stock $8.84. I got several from them not too long ago.
How far away can these things be mounted? does there need to be a stright line between the machine and the turnout, or can the wire be guided trough a sleeve like model airplane controls?
Circuitron specifies 18 inches but I am sure that could be extended by a savvy modeler. [:)]
The control wire does pass through a sleeve. The instructions say up to 18" away and not to exceed a 2" radius in the control wire. My control wire ended up about 12" and goes through a 45 degree angle.
$8.55 here:
http://www.dallasmodelworks.com/products/product_detail_accessories.asp?ItemNumber=CI-800-6100
INGENIOUS !!! [bow]
Wolfgang, please post more detailed instructions as to how you mounted the Tortoises and what you used to get them to work horizontally. I am sure there are many others out there who would love to know more.
Like you see here, I’ve used two brackets to mount on the piece of plywood. I’ve attached the tortoise to the plywood.
You see the wire from the tortoise protudes under the plywood ad goes into a hole at the brass rod. This way the switch motor moves the brass rod. I’ve used terminal strips like you see. There’s the tlhrow bar wire soldered.
My latest version goes with brass tubes and piano wire for the throw bar:
Wolfgang
Meant to reply a few days ago. I got their last 3 with 3 more on backorder. They arrived on Monday, the first was installed yesterday. While the instructions are clear (after reading them several times) actually doing the install was a bear. That was due to reason I needed to use the remote in the first place. I could see where the actuator went, or I could get my hands up there, but not both… I am renowned for my poor planning. [:-^] I finally did get everything installed and it works beautifully.
I have also done many other remote installations with home made throw bars. (I’m part German after all Wedudler…[;)]) Here are some that I did a couple years ago for the area above hidden staging using some old code 100 rail I had laying around:
after the backdrop was installed:
This one goes in an area where there is no room for the tortoise to be placed under the track.
Here it is before it was installed:
