[:-^] Can someone help. Are we allowed to ask where one can have some wiring repairs done on a brass steam engine. I have several that need re-wiring and was wondering if someone could let me know, (if possible?) where I could send them, someone reliable.
When you say “re-wiring”, what do you mean? As in, add a DCC decoder? Or replace a lightbulb or resolder a drawbar? Because most brass steam engines don’t have much wiring from the factory. Only the most recent steam from Division Point and others have much in the way of wiring.
Try All Brass Backshops you can do a search for them. Pretty much full service on brass. Pretty well known in the NY/NJ area. Mark has done three paint dcc conversions for me and very pleased.
[bow] Thanks to all of you. My engine has two wires, one on the right side, where the insulated wheels are, it is a short wire soldered to the cross bar that conects the engine to the tender. Then there is a long wire on the left side of the locomotive that was soldered to the floor of the tender.
I disconnected the long wire then re-attached it and the engine did not work, strange. Then I took the long wire and touched the track, the engine would run, same when I touched the wheels tire tread on the left side.
After cleaning the drivers of excess grease and oil, I tried to re-insert the springs on the nipples and place the drivers back into the grooves on each side of the chassis but could get the rods lined up right to slide the drivers back into the slots. I was concerned that I would bend some of the driving rod, so I have sent the engine off for repairs.
Funny how you can slip the drivers out of the chassis of a Spectrum locomotive, then slip them right back into place, yet it’s much more of a challenge with brass engines.
