My rolling stock is jumping off the tracks, identified that my bachmann spectrum rolling stock (pretty new, maybe 3 hours total use) the metal wheels are crazy sloppy/loose and are causing the rolling stock to derail
question - as I don’t care about them being aesticically visually identical (if they look different, i don’t care).
is there a specific brand/type that people recommend or do i have to purchase from bachmann directly
these are currently on the rolling stock:
6 wheel trains
metal wheels
they unscrew from inside the train car; if that matters.
If the trucks are on virtually new cars, I’d contact Bachmann and see what they’re willing to do. Sounds like a warranty problem to me if things are truly that bad already, maybe some quality control issue or ?
The wheelsets in trucks generally fit loosely, allowing for limited sideplay. Is it possible that what you’re observing is normal, but something you’re not used to seeing?
Are these passenger cars, since you mention 6-wheel trucks? What radius curve are they derailing on?
A few years ago I replaced the rest of my old plastic wheels with Intermountain metal wheelsets. It was a worthwhile endeavor, as my rolling stock is much more free rolling. While doing this, I found some old Athearn trucks that were so loosey-goosey that the wheelsets wouldn’t stay in, and a bunch of old Tyco metal trucks that couldn’t be disassembled for wheel replacement.
I needed a bunch of truck frames, so I looked around and found packages of Tichy trucks for a very low price. These fit the Intermountain wheelsets perfectly. Tichy makes these in a variety of styles by a variety of prototype manufacturers.
Yes, they’re ugly black plastic, but a rattle-can of Rust-oleum and a dusting of weathering powder gets them looking like they belong under a freight car.
If you’re replacing wheels or trucks, get a Micro-Mark Truck Tuner. It lets you easily ream out those conical axle bearings in the truck to give you the best performance.
Welcome to the hobby, and unfortunately your first problem. To answer your question there are many manufacturers that make ‘trucks’ for trains. We call the assembly that holds the wheels and axles a ‘truck’ (a ‘bogie’ in foreign countrys - a term that you will hear here too).
Truck manufacturers are Central Valley, Walthers, Model Die Casting, Athearn, just to name a small few - there are many. Being that your trucks (you have two, one at each end of car) are screw mounted, they are an easy candidate for replacement by any company who makes a truck that will fit the “Bolster”.
A bolster is the crossframe that the trucks mount to under the car. This is important because not all manufacturers make the same size hole in their ‘crossmember’ (the part going crossways on your truck parallel to the axles with a hole in it for the screw) nor do they make the same size bolster (on bottom of car) for the truck to attach too. Some, but not all are universal. Some arent even screw type - they snap in. Those are a pain!
Another major thing to consider when swapping trucks is “ride height”. Not all trucks sit the same height from the rails (ride height). This is important because it can change your “coupler height”. You may fix your derailing problem only to bring upon yourself a coupler problem. Couplers must line up for proper oper
The photos are my old stock. The plan is to increase the car weight of 5.8 oz (165 g) to more than the NMRA recommended 7.1 oz (200 g) and to convert couplers to fixed body-mount Kadee.
PS: Do nothing else and try increasing the car weight to 8.8 oz (250 g). It will be profitable if the passenger car does not derail with this.
