Reverse loop question
I have a reversing loop with an AR1 on my layout. I was running my E7 the other day and when I tried to go through the Reversing loop I heard it trip but it still shorted. It is a 4 by 8 and I resently took the AR1 off the layout for a move and reconnected it. It worked fine before the move so I don’t know what the problem is. Can someone help me?
sfb
This has become a recurring question as of late. To operate properly, the reverse loop must be isolated (both rails on each end of the reversing section must be gapped) from the rest of the layout. No feeder wires from the reversing section can be wired to the bus wires for the main layout. The main layout bus wires feed into the input side of the AR1. From the output side of the AR1 a separate set of bus wires must be used to power the reversing section. Within the reversing section, multiple feeder wires may be used but all of the feeder wires in the reversing section must be connected to that separate set of bus wires on the output side of the AR1.
I am pretty sure that it is wired correctly but I’ll go check. I’ll keep you posted.
This diagram may help.
If you do have your layout wired similar to the diagram above and are still getting booster tripping problems:
Try turning the adjustment screw on the AR-1 counter clockwise. This reduces the trip current before the AR-1 switches the phase. Your AR-1 manual will tell you how to do this.
(This bit of advice is attributable to DigitalGriffin)
Well, almost every time, the problem is where the hands were last. It worked, you disconnected it, you reconnected it, and now it doesn’t work.
Double check everything. Also, perhaps in the move, you created a short somewhere. Get your meter out, and triple check.
steamfreightboy,
Where are you?
What happened?
I check and it seems like everything is wired right. Should I try disconnecting it and starting over?
If you are absolutely convinced that it is wired correctly and the ends of both rails are gapped at either end of the reversing section, then you might check the suggestion to try turning the adjustment screw on the AR-1 counter clockwise. This reduces the trip current before the AR-1 switches the phase. If that doesn’t solve the problem, let us know. No point in having a non-functioning layout. Just out of curiosity, how many sets of feeder wires are there inside your reversing section. I ask because if there are not too many, you can easily trace the few feeder wires you have to be sure that none are connected to the main layout bus wires.
Checked with your eyes or checked with a meter?
There is only one set of feeders going to the section and I checked the entire run of the wires from ar1 to the section as well as the ar1 to bus connection and it was hooked up acording to the diagram. I’ll play around with the trip current.
If you still have a problem after turning the adjustment screw on the AR-1, disconnect the AR-1 and innstall a DPDT switch in its place. If that works, then something is wrong with the AR-1. If it still doesn’t work, something is wrong with your wiring.
Check your gaps. If you moved things, something could have shifted.
Okay, I will.
I was interested in the auto reversers, but was told that they only work with DCC, is this true? Yes, my layout is “old school” DC.
Yep, it’s true. I believe the autoreverser would resolve the short (never done this, so that’s just a guess), but when the train was leaving the reversing section the polarity would get switched under the train, so it would immediately reverse itself, until it tried to leave the other end, where it would reverse itself…
In DCC the phase can be reversed under the train, and it will continue in the same direction, that’s why it works in DCC, but won’t in DC.
Yes and no. An AR1 autoreverser will “see” a short circuit and reverse its ouputs even with DC power. Solid state reversers may not, I’ve never tried it with one.
Problem is a DC engine will also reverse direction when the polarity is reversed. It backs up until it attempts to cross the gap at the other end. AR1 sees the shrt circuit, reverses polarity. The DC engine reverses its direction and heads back to the other end of the reverse section. Kind of like a game of Ping Pong.
Martin Myers
This thread is very timely. My reverse loop has worked flawlessly for several years with a PSAR reverser. Recently a section of track at one end or the loop lost power and I was in the process of adding feeders to it from the main bus.
Rich, thanks to you comments I now know better. After several years I had forgotten how it was wired.
As for the op’s question this may or not be applicable. I did have a problem with plastic rail joiners. The track joints were so tight that the track expanded through and made contact with each other. Cutting a gap with a razor saw solved that problem.
Happy Railroading
Bob
Yes, an auto reverser will work with DC - but with limitations.
With DC, because the engine reverses when the polarity is changed, the auto reverser must change the polarity of the track the train is entering into, not where it is. So the auto reverser is wired to the main and trips off the exit reversing loop gaps. Note this only works for the exit from the reversing section, and cannot match the main and reversing loop at the entrance to the reversing loop - this must be done via another method. A second auto reverser does not help unless they are wired to separate sections of track so they can detect shorts independently.
There is also the issue of operating trains at low enough voltages on DC that the auto reverser might not sense the “short” and change the polarity in the desired milliseconds.
There are automatic solutions for DC that use position detection to set the polarity of the track ahead of the train, rather than waiting for a short circuit to happen.
Fred W
steamfreightboy,
Update us. What is happening?
