So i have A rivarossi drefuss Hudson that i tested the motor with a 9 volt battery and it runs, but I don’t have the correct tender that originally came with it. I have a rivarossi casey jones tender that also has a drawbar with a hole and metal rod sticking out. Is there a way I can use this tender to run the rivarossi hudson?
Unfortunately, the pairing would look ridiculous - the tender is way too small, is not equipped to provide coal via a stoker and it ain’t streamlined. I would hunt up a spare tendr on the used market. BTW, you might be able to use a Challenger or Big Boy tender as pseudo PT type tender as some Hudsons were so converted in later years. The Dreyfuss Hufsons were also stripped of their cladding, so this could be an intermediate step. And a shrouded Hudson would not look bad with a PT tender Check out the second hand market on line.
Do you live in the lower 48? If so I can send you a proper tender.
Hudson Tender AHM by Edmund, on Flickr
My email address is in my profile.
Regards, Ed
Ed, I think I take you up on your offer! thanks for offering! I tried the links you provided and I can’t find your email address In your flicker profile. Can you please provide me with your email so I can forward you further information on this matter?
thanks again!
James
By the way the rivarossi Dreyfus’s engine number is 5446
I meant for you to look in my Model Railroader profile. Click my ‘avatar’ and on the lower-right of that page you will find my email address.
Good Luck, Ed
I am getting a server runtime error when I try to tap anyones profile for some reason.
Only certain browsers can still access profiles – you can’t do it at all from a phone, for example.
I have an e-mail address in Settings for display on my Profile page – it isn’t there and has not been there fir years. Since new PMs have also become impossible, the only ‘solution’ is to provide the e-mail in a post with the usual obfuscation syntax tomfoolery like overmod[at]icloud[dot]com.
thanks ed for your generosity!
I jus sent you 2 emails one with the address and the second with pictures of my rivarossi Dreyfus’s engine. I forgot What website I used to upload pictures here so I emailed you pictures of the actual engine. James huff
OK, James. I’ll check that email.
The Hudson the tender comes from is also the 5446 but the number isn’t on the tender anyway. I bought this engine while I was still in high school (1972 or so).
Rivarossi_AHM_Hudson by Edmund, on Flickr
I’ll get it in the mail by Monday.
Good Luck, Ed
thats exactly what my Dreyfus’s engine looks like!! If only I can remember what site I used to use to post my pictures i can post my pictures of my rivarossi drefuss engine here!
