Starting to build roads for the layout. Where can you get white and yellow stripes?
I’ve seen some you can buy but the thicknesses vary. I just need them for HO. Do those Woodland Scenic markers work?
Ah, yes: STRIPING. The other spelling brings up much different concepts.
I recently saw a very nice example using chart tape. For a long while, road striping has had thickness. And so does the tape.
It looked great.
Ed
PSF Hobbies has 1/32” and 1/16” Yellow and white striping tape. The 1/16” works great for HO scale road striping (5¼” wide).
Mel
My Model Railroad
Bakersfield, California
LOL It didn’t look right to me, asked someone sitting next to me and they thought stripping also
I’ve seen a video, that I think was MRVP, where they masked and painted them with an airbrush. I know they have used a pen, by Woodland Scenics, looks like a yellow magic marker with a thin tip.
The only problem I had with the striping tape was prepping roads so that the tape would stick. The self stick adhesive didn’t like the Arizona Rock & mineral pavement. It stuck best after a quick wipe with Acetone then waiting a few seconds and apply the tape. After the tape had been on the pavement a few days I used a new sharp #11 blade to remove sections for the broken lines.
I also did my thing years ago with an airbrush but the tape is less messy, easier and is no way as easy to screwup as painting.
The tape has held pretty good, its been on the roads for over 5 years without any of it coming loose.
Mel
My Model Railroad
Bakersfield
I believe the chart tape I saw was applied to painted “plaster”. I don’t know if the guy had problems with it, except he did say it didn’t much like to curve.
Ed
I don’t have a very good photo of the road, this will have to do —
HO_Texaco1 by Edmund, on Flickr
I used Durham’s Rock Putty for the highway surface, primed it, then airbrushed a white band where I planned to have stripes.
I applied tape. I do not recall now if I cut my own tape on a piece of glass (I believe this is what I did because I wanted to use “light stick” painter’s tape) or did I use masking tape already cut. In either case, it was a simple matter of placing a single strip where I wanted it, then paint a dark gray, almost black, coating over it.
Automotive paint supply houses have many types of narrow masking tape. Ebay and Amazon, too. There’s also “nail-art” tape. I have some of that which is only .030 inches wide, if you need a narrow stripe.
Last step, of course, was to carefully peel away the tape. In my era the “double-yellow” hadn’t been adopted yet.
A double line can be done the same way, but with a little more care in placing the tape to keep the lines parallel.
Good Luck, Ed
Ah, the Achilles’ Heel of my modeling talents. I have never been able to make a striped road look correct.
My last two layouts featured no paved roads! That solved the problem for me.
I will need a solution for the next layout. The plan is for several paved roads, and one is a highway section!
Plan around your defficiencies!
-Kevin
