Sorry i typod as i was using my auto correcting phone to post its green glue not green goo http://www.greengluecompany.com/
An article by Pelle Soeborg got me thinking about when I used to install furnaces and A/C during college, and the tape we used to seal ducting.
I’m considering using this product. Two strips side-by-side will be the same width and thickness as cork roadbed, will help navigate curves like cork roadbed, is self-adhesive (sticks like heck), and seems to round off at the edges. $9 for 25’ - not too bad, and cheaper than cork at many outlets.
http://www.bestmaterials.com/detail.aspx?ID=9591
Whatcha think guys?
Have fun!
Dan
That was actually once sold as roadbed. It’s ALMOST sticky enough to hold the track with no adhesive or nails. AMI Instant Roadbed. Some people liked it. A friend of mine used it on part of his N scale layout, over time the track let go. It’s still solidly stuck to the plywood though. I would not trust it to be self-adhesive, but it should be a decent option.
I will not dispute the detailed technical advice regarding various methods of sound control outlined above, but I will suggest a much simpler approach that I have found to produce quiet results, results that are more than “good enough.”
My benchwork is open grid framing covered by 1/2" plywood screwed not glued) to the framing. 1/2" Homasote sheet is fastened by screws (not glued) to the plywood. This Homasote sheet-though not perfectly uniform in thickness-is uniform enough with the provision of a very few track shims at low spots and minimum sanding at high spots (primarily at joints). This sheet is the “roadbed” to which spurs and sidings are attached.
Actual roadbed is Homabed attached to the Homasote sheet with brads (not glued).
Track is Walthers/Shinohara Code 83 spiked (not nailed or glued) to the Homabed and Homasote.
I have not yet ballasted the track, so its affect on the assembly is yet to be heard, but trains running on the above-described assembly are very quiet, generating only wheel noise and clickety-clacking over the joints.
Dante
IMO, most of the noise comes from ballasting the track, which effectively allows the vibration to bypass much of the preventative measures used when installing the roadbed and the track.
I have read different modelers trying different combinations, but I have not yet heard of anyone trying something that Hornblower mentioned above…
Isolating the ballast from the subroadbed by using waxed paper on the subroadbed to create a small gap,then removing the paper after the ballast has hardened.
A lot of modelers mention how the noise increases after they ballast, so experimenting with this installation technique might be educational.
I was making some up grades to a setion of track that was not ballasted. About 2’ away was a section of track that was ballasted. When I was finished I pushed , by hand, two passenger cars to check the track work. When the cars rolled onto the ballasted section, the noise increased by at least 50%. I never noticed this noise before.
The ballasted track was done years ago using diluted white glue on cork roadbed. The roadbed was nailed to 3/4" plywood.
I’m not going to rip out the track that is ballasted, but I will rethink how I do the next section of track.
South Penn
Matt medium is the way to go, on a 4 to one ratio, you get alot. I can buy matt medium at Michael’s for $12 for 16oz or equal to 4 bottles of thw Woodland Scenics stuff, enough to do my entire 15x30 layout almost (I have a rather large yard that is covered in ballast).
What matte medium are you buying from Michael’s? When I do a search for it on Michael’s site the only clear matte medium that comes up is Modge Podge.
I’ve been using caulk to glue cork roadbed on 1/2" ply, then paint/seal the roadbed with enamel wall paint, then glue the track onto the roadbed with the caulk, then Scenic Express natural stone ballast with diluted white glue.
I get very little noise with the track just sitting on painted roadbed (stuck on with double sided tape or nailed down in spots). The noise is much louder when the track is caulked down, and noisier yet when ballasted. Diesels are still pretty quiet but wheel noise from steamers is very noticable. Double-heading two Spectrum 2-4-0’s is the worst even with the speed tables carefully set.
I just laid some new track on cork roadbed using push pins through some of the spike holes, then cut the pins flush with the ties. I am thinking of skipping the caulk and ballasting the track as-is. Does flex track have to be firmly spiked down or glued down before ballasting? I don’t want any trouble down the road but thinking skipping this might reduce the noise.
Michael’s sells Liquatex (a known brand) in two sizes, 8 & 16oz in store and I use a 50% off coupon. Part of the proublem is using plywood. I use foam and it transmits sound much less but to realy get rid of the sound you need to eleminate the drum, haven’t gotten to that part on my layout as the skirting will eliminate a lot of it. I experimented with covering the bottom of a module and 1/2 the sound seemed to go away (and I wasn’t very carefull with doing the mockup). Was thinking of getting a sound meter, they are cheap, but I get tired of having to reinvent the wheel, too many people are tied for some reason to the way something was done, to do new and better ideas. They said not to use beaded foam, I tested it and looked up date on a fire ferensic web site and found that the way we use it, that was hogwash, I find a lot of this stuff, as my daughter says, the internet is our friend!
Liquatex is available from Amazon.
South Penn
You linked to the gel, not the liquid.
I’ve used both matte medium and white glue for ballasting. The only difference I’ve noticed is that white glue is cheaper. [swg]
Any flavor you want. http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Darts-crafts&field-keywords=Liquitex+Professional+Matte
South Penn
After my experiance earlier, I have been paying more attention the noise on my railroad. In this case, a train went from a non-ballasted section of track to a ballasted section of track with no change in the noise level. If anything the ballasted section might have been a little quieter. The ballast was installed with white glue, but, the ties are wood. Hmmm…
South Penn
You want less noise, try open air, the train makes almost no noise on my high steel trestle.
Bingo! I have posted my own supporting observation a number of times on threads where train noise is being discussed. My bridges, no matter what type, plastic, metal, scale timber trestle…makes no never mind…as soon as the loco begins to run on a bridge on my layout all the noise stops.
I have been ballasting my beach sand (AKA cheap) ballast with yellow glue diluted to run into it easily. The glue does a good job, and doesn’t seem to make the ballast look shiny. But, it makes a great sounding medium.
I found, eight years ago when I had to dismantle my very first layout so that we could lay carpet in the newly finished basement, that drywall strips are amazingly quiet. I set up a small switching layout to get me by while we finished the basement, and I used scraps of drywall for roadbed. It was whisper quiet. Takes track nails really well, too.
-Crandell
Hi from Semafore, site member. If I may interject, there is a track conditioning treatment by the title of ‘Gleam’; beyond the great reduction in drag, increase in steady traction and electrical pickup, this method also significantly reduces roadbed noise. Who knew?? The rail noise diminishes so much you can hear the whirr of the motor in the loco, and distinct click-clack of wheels. And best of all, minimal maintenance, time, and expense. Please search forum for ‘gleam’ to garner more info. My original post in 2006 will explain proper simple method; hope your elbows are good! Sincerely, Semafore
While using matte medium instead of white glue for the ballast, is one good idea, I think you need to skip the cork and go with foam roadbed, like Woodland Scenics sells. You want to isolate your trains from the wood and walls.
The more solid the subframe is, the lesser the noise will be.
To really get a quiet roadbed, use the 1/8" thick sheets of black rubber/bitumen that are used by the car sound crowd.
Place it between the subroadbed and the cork for good effect. Do not let the ballast go past the rubber sheet, or the sound will be transferred to the subroadbed!
If you want no sound transmision, fill the underside of the layout, not very practical but works. One can design the layout using modules and have it so a foam sheet can fit the bottom.
