Has anyone built a rolling platform for benchwork. My proposed layout is 14 long an average of 5
wide but the layout has a dogleg of about 30 degrees at the 9 mark which would put 4
of it against a wall with 36" of the end of it against a right angle wall. The problem being that the room is only 8
wide and I want to be able to comfortably reach all parts of the layout and do NOT want any access hatches on it. I realize that I could simply not put casters on the legs of the L girder benchwork (I have too many tortoises to use open grid) because of the lateral stresses on the framework in moving something this big. What I thought id do is build a platform on rotating casters then put the L girder benchwork on top of that so that when I want to move the layout I
m only putting stress on the platform which will be built out of 2x6 with a cross joists of 2x6 by 5` on 16 inch centers topped with 3/4 inch subfloor plywood for diagonal bracing.The platform would be 12" wider than the width and length of the L girder legs.I would mount 3 casters on each of the 2 header members and would roll on a flat smooth concrete surface.This would give me adequate reach over all parts of the layout.I thought about mounting it on 2 rails but this would not give me movement on all axises. Any suggestions are always appreciated.
Bob D
