Hello All,
Using a rolltop desk to hold an N-scale pike doesn’t seem too farfetched to me.
“Hiding” a pike in a piece of furniture is not a new idea. Some layout plans are designed to be stored under beds or in closets. While others are built in modules for storage.
Obviously, modification to the desk would be necessary.
Depending on the construction of the desk I would begin by removing the pigeon holes. Some reinforcement might be necessary after these have been removed.
Adding kitchen type under cabinet lighting would illuminate the far reaches of the pike.
I would use 1-inch blue/pink foam as a base.
Brackets could be installed to hold an additional lift-out section. This section would have a thin plywood or Luan base.
Imagine a trundle bed but rather than pulling out and up it would be pull out and down.
The top, side drawers, could be modified to support this lift-out section with latches or pins.
Controls could be stored in the center drawer.
A fold-out control panel could also be fabricated for the center drawer for turnout control, depending on the depth of the drawer.
My 4’x8’ pike sits on the bed in the spare bed/computer/railroad room. There is little to no under pike access.
For the wiring I used 1/2-inch automotive split flex tube. I cut out channels in the foam to place the flex tube and then ran the wires through these.
This allows the pike to be sceniced without burying the wires.
It might be unsightly but routing the wires to terminal strips mounted outside of the back of the rolltop would simplify trouble shooting.
Holes could be drilled in the back of the desktop to route power cords into the foot well where a power strip could be mounted.
The remaining side drawers could be used to hold rolling stock, modeling supplies and/or controllers.
A project like this might involve more cabinetry skills than a traditional pi
