Roof grab irons
Greetings,
I’ve been doing some bottom stirrup repairs on a few HO Proto 2000 boxcars lately and have enjoyed the learning process. (Thanks, Wayne!) Given the narrow width of the shell along the bottom edge, drilling a parallel hole to the wall so it does NOT poke out the sides can be challenging and shouldn’t be rushed. It is rewarding though when you’ve done it correctly:
This 50’ auto boxcar won’t suffer from another broken stirrup anytime soon. [:P]
My query is about roof “corner type” grab irons: Were there variations of them on boxcars and cabooses?
The reason I ask is that I have some Tichy #3028 roof grab irons that only have two end points to drill. Would that type generally use an eye bolt to secure the center or corner of the “L”? (I’ve seen these on cabooses.) Were there cases or eras where securing the roof grab iron with only two ends brackets (no corner bracket) was preferred or advantageous?
Thanks for the help and understanding…
Tom, I don’t recall ever seeing a real corner roof grab with only two legs supporting it, but it’s not something I really looked for when roofwalks/running boards were still in use.
The Tichy corner grabs were, I believe, originally created for the Tichy boxcar kits, the roofwalks of which had a moulded-on peg which acted as the middle leg - basically just a support, with perhaps of drop of ca to secure the wire to it.
Some kits, such as Intermountain and Red Caboose, along with Proto and likely others, include one-piece plastic roof grabs with three support legs, but I build my own using Tichy .012" phosphor-bronze wire or similar size brass wire.
To that end, I created a small jig from hardwood, which allows me to build four at a time, and I’ll often devote a complete work session just to that task, making three or four dozen in one sitting.
Here’s the jig, a small block of maple, with a smaller and thinner block glued on top…
I drilled a #79 hole (completely through) the bottom block at each corner of the thinner block, then used a utility knife to remove the corners of the thinner piece. This allows room for the middle leg’s partial loop and for the tip of the soldering iron.
The two piano wire (.060") pegs at each corner have just enough space between them and the thin block to allow the pre-bent wires to be placed in the jig.
The two thinner pieces (.015") of piano wire sticking out of the upper piece are used, with a small pair of smooth-jawed pliers, for bending a partial “eye” in the short piece of wire which forms the middle support leg.
The four partially pre-bent wires are longer than Tichy’s, as I prefer, where possible, to drill through not only the roofwalks’ laterals, but also right through the car’s roof.
Many of my cars don’t use comm
Man! - More of these kinds of how-to’s should be in MR. Great stuff as usual, Wayne! [Y][Y] I love the scorched marks in the maple jig where you soldered the center vertical support to the L-shape roof grab iron. Looks like it’s been well-used. [:D]
I was going to reply to this, then I read Wayne’s reply, and now I need to build one of those jigs. That is amazing.
I will probably use Tichy corner grabs and 0.012" eye pins, but the idea of soldering them before assemblylooks like a real frustration reducer.
Thank you Wayne!
-Kevin
Not the least of Wayne’s skills and not the least of the virtues of his tutorial posts here, is the very clear prose – it is not easy to write so clearly about technical matters.
Dave Nelson
I found this fantastic photo:
You can see the very typical method of tying down that irritating grab iron corner. Considering how sturdy that bit of metal is, it seems very unlikely that it was ever left off of freight cars after the early years of using such grabs.
I believe he is either setting or releasing brake retainers. And that the location is on the SP or Santa Fe, down near LA.
Note also the curved roof of the car the photographer is standing on.
Ed
Thanks for the kind words, guys! [:$]
Ed, that’s a great shot of the guy setting the retainer.
As for radial roofs, Northern Pacific favoured them, and CPR used them on some Fowler boxcars and on their long-lived “Mini-boxes”, too.
A cursory look in one of Ted Culotta’s books also showed a 50’ Missouri Pacific automobile car so-equipped.
When I re-built some 40’ Tyco reefers into 36’ truss rod cars, I opted for radial roofs, too…probably fairly unusual for reefers, although many express reefers sported such roofs, too.
Yea - great photo, Ed! Thanks for posting it! [Y] There’s so much to absorb - even from just one photograph.
And given that the roof grab was secured to the wood slats, I would think that having the corner secured would help keep the securing brackets on the ends from working loose due to oscillation.
Hold on there, pardner. If you look closely at the various hardware bits in evidence on those wood slats, you’ll see a rather neat and straight row of what looks like carriage bolts. You can also see there’s a good bit of air underneath the slats. From this, I claim that there’s a bit of angle iron underneath. It’s side is attached to a long strip of wood that’s going left to right. The carriage bolts go through its top. The two grab iron mounts that you can see ALSO have bolts through this angle iron.
That’s how it looks to me. So the mounts aren’t just attached to the slats. They are attached through the slats to a chunk of steel that ties the whole assembly together. Much safer that way.
Ed
