Always thought saddle tank engines were neat and with that in mind I uncovered an old Lionel 0-6-0 with outside drive gears that I had kit bashed several years ago. It wasn’t a tank engine but it had a neat cab and unusual stack which was a little bent due to a smoke unit over heating. I had build a small tender to go with it to improve electrical pick up as the were no rail sliders . The drive system was so poor that I had to undo 1 of the driver wheels from the drive rod to get it to run as the gears were constantly getting out of sink. So I ditched the Lionel drive and substituted an LGB 0-4-0 engine # 2015, I reused the smoke box front the Lionel, making the body out of PVC tubing, added part of a Aristo-craft 2-4-2 Rogers tank buy cutting off 1 section of rivets and placing it on a piece of flat styrene that I sawed a slit in the piece of PVC tubing and inserted left to right into the slit leaving enough over hang or some side running boards. I cut the 2015 down on both sides and left the motor block housing. The Lionel cab had 2 tanks on it 1 left and 1 right on it’s front and cut them off, made doors out of styrene and arched them like the windows before were done and cemented them in a open mode. The left side of the engine I suspended from the running board a scratch built ( out of styrene tube ) air tank adding piping with brass wire, on the right side I added some leftover cooling tubes from a Aristo-craft switcher. Put an air pump, I believe from an LGB engine, attaching it to the left side front of the tank also piping it with brass wire. Not quite sure where I got the sand dome but it fit the old time looking bill. After researching old saddle tank engines I discovered some of th
That’s a nice looking kit bash, thanks for sharing with us.
It may be “new” but it has the look of “have I got a story of hard work.” Well done and thanks for the share.
Until I see a Florida company name on her, I am calling her “Loke,” Hawaiian for “Rosey!”
Hey now I like that cab/body combo, even got me a Lionel cab like that
Really suprising how close the cab was to the orginal 2015 one, had to cut out som small tap parts but other than that in slid right back in where to orginal was, hardest part was making dooes for the front of the cab where the rounded windows were, thanks for the kind comment, Bill
I agree that “Loke” or “Lokemele” would be great names for a job well done! There is another plantation Modeler in Hawaii? LOL. Thought I was alone out here.
Neil Erickson (aka Eric San)
Neil,
Shall we say “plantation inspired?” I am taking my strategic guide off the OR&L, but I am just having fun gaining some experience as I slowly shape my own line, the Oberammerga, Ogden & Olomana (the “Triple O”) over here on O’ahu!
Eric
