Just took the plunge into DCC with MRC Prodigy Advanced, installed my first decoder and it works!!! I need to purchase the 8 pin plugs used for the decoders. Most all of the articels I have read recommended using these plugs for future change out of the decoders. Ummm where do I gets these plugs? I can’t seem to find them anywhere… Could you help a guy out?
I have over 250 locomotives 80% of which are older models. I’ve been told that the high amp draw will cause problems. After reading about decoder burn outs on older Locos. I guess I’ll have to start over… No matter I just love the DCC… Thanks in advance
The plugs are not what you need and will do you no good if your locomotives are older and do not have a matching socket.
Decoder dealers usually have wiring harnesses with an NMRA plug on one end and a JST 9-pin header on the decoder end, but these will do you no good either unless your locomotives are newer “DCC Ready” ones with a socket mounted in them.
You can find out about NMRA plugs, sockets, wiring harnesses, etc. at Loy’s Toys, Tony’s Train Exchange, Litchfield Station, or other on-line sellers of decoders.
Sorry it took so long to get back to those who replied. Thanks for the info. I skipped the 8 pin plug, and hard wired my first loco. Worked out well, and not using the connector saved room.
Once again you guys came through, many thanks from a greatfull Modeler…
With 250 locomotives, you might want to consider either thinning the herd, or converting some to dummies, or building a display shelf, or taking out a mortgage!
