I found a 234W tender at my parents house in VG condition. The 243 Steamer was trashed, actually held together with electrical wire! I soon found out that the reason the tender is in such great shape is because the pull bar that the engine attaches to was cut off just beyond the hole! I know I can remove the truck, but where do I find a replacement?? I apologize for not knowing the correct term for this “pull bar”.
You’re close; it’s a “drawbar”. I would make a replacement piece, of either brass or steel, and solder it to the stump with a lap joint. If you want it completely authentic, someone else may be able to help.
The drawbar for a majority of postwar, and prewar tenders are the same part. Normally I would direct you to Trainz.com, but it seems that their website is going a little haywire right now. Check back with them and search “drawbar”.
Thanks Butleryard. Everyone has been so helpful, I love this Forum. One question? The part numbering is very confusing. Lionel has it listed as 80-6026-007. Some stores sell it as 6026-007. When searching for a part how do you know how much of the number to use??
John, for an example, we will use your part, the drawbar. The postwar # 6026-7 is the number most stores would go by.
Then came the modern era, after postwar and Lionel change/ added to their numbering system and added a 3 digit prefix to most of the parts because they came from the postwar era and now were used on some of the modern issued trains.
