Running Light
Could someone explain to me how the term running light came about for trains. When I see videos you see engines returning to the yards and the narrator says they are running light. When you look they are no cars but just engines. Wouldn’t this be running empty? I know someone will set me straight on this.
Larry
Hi Larry, its just part of the culture. We dont say we coupled the cars, we call it making a joint. Light engines is a funny term, there is nothing “light” about any locomotive. And if you have two or more engines running light, the gcor calls it a train. But the locomotive dosnt contain anything, so it cant be empty. Cars are refered to as empty or loads, (sometmes heavy or light, depends where you work). Because the engines are not loaded or unloaded, just provide the power, they are refered to, when not pulling cars, as light, (meaning the “load” they are pulling is light,ie, no loads) We refer to loaded trains as heavy, empties as light also, so a best guess would be the term means without loads.
Ed
Ed, thanks for the answer. I’m catching on.
Larry
