RW Transformer Variation
I’ve just been looking at available RW transformers and noticed some have a black UL symbol and others have a red Lionel “L” in the upper left corner. Any information on the change? Thanks in advance.
[#welcome] QuarterDriver!!!
Not sure what your looking for but here are some links to look at. I think they are the same inside. But can’t bet on it.
The L is for Lionel, The UL is for Underwriters Laboratories. Just something that was big back then. To say they were safe to use.
http://www.tandem-associates.com/lionel/lionel_trains_rw_transformer.htm
http://postwarlionel.com/everything-else/transformers/rw-transformer/
PS
Thanks for the information on the RW. What I found interesting, or wierd if you will, is that looking through ebay listings, I see more “UL” transformers than “L” ones, but all of the Lionel literature has a drawing with an “L” type RW on it. Even your link http://postwarlionel.com/everything-else/transformers/rw-transformer/ shows a “UL” marked RW transformer, backed by original operating instructions, with an “L” marking on the drawing. Why would Lionel do this? Was the “L” type along with instructions produced first, and the “UL” type later and they just kept printing the same literature to save money?
Perhaps just another one of those little Lionel mysteries.
Just noticed that there’s yet another RW variant: One has the text “TYPE RW 110 WATTS” in a single line, and the other (and seems to be more common) the smaller word “TEXT” over the larger letters “RW” in a line that says “110 RW WATT.” Apparently none with the single line of text are “L” units; all I’ve seen are “UL.”
