Doing some research on area rail served industries, I stumbled upon a home page of a sand quarry/dealer here in GA. Linked in their public home page is a pic (scroll to the right if you have too) of a string of open hoppers loaded with sand. Looking at google maps, it appears to be a spur connected to either NS or CSX mainline, not just some internal shunting operation.
My understanding is that sand should be kept dry for transport, changes the weight way too much if wet, and is typically transported by rail in shorty covered hoppers.
I have also seen photos of sand shipped in gondolas, both very old photos and fairly recent ones; when the first frac sand was being shipped from Wisconsin it was in open gondolas, later is shorty covered hoppers. What surprises me is that a regular hopper car’s gates are tight enough to hold sand in - I’d think much would be lost due to leakage during transport. Modest evidence of the problem is that you can tell where ore jennies have been from the amount of taconite pellets that you find in the ballast.
Yes, the raw sand was, headed to be refined. Once it was refined into the clean dry silica sand ( aka Northen White sand), it’s then shipped in the 3 bay covered hoppers.
It may be different now, but historically railroads received ‘wet’ sand in open top cars and then dried the sand in the sandhouse to use in locomotives. I would assume if for some reason a railroad had to transport the dry sand somewhere they would use a covered hopper or other enclosed car.
Yeah, but can you imagine the sand castle you’d get if a hopper loaded with wet sand was flipped-over, then the hopper-car lifted off? Way better than the plastic bucket-at-the-beach version! [swg]
That’s interesting. I was under the impression that it mainly moved in 2 bays because of the weight. The only silica facility I’m familiar with is the one in Berkeley Springs, WV and they’re an all 2 bay operation.
I can confirm that in the 1980s and 1990s the sand mined in Hendry County, Florida left the quarry in open hopper cars.
A floating dredge was used to pump the sand from the quarry lake to the power screen. Thus, all the sand was wet when it was loaded into the hopper cars.
So raw sand gets quarried, loaded, then transported to a refinery of sorts where it gets processed into higher quality sand? (if there is no processing facility on site) Makes sense.
What does a sand processing refinery look like? A few conveyors, silos, and metal pole buildings? Any ideas where I can get a pic?
Interesting modeling possibility. Open hoppers of sand as input, covered three bay hoppers as output.
Sand is still sand no matter refined or not. Handling in open top cars under inclimate weather would still be a mess. Yet, i have seen sand hauled in hoppers and gondolas myself.
Car-shakers wouldnt be out of the question for todays operations for ‘wet loads’. Rotary dumpers would completely eliminate the hassle. Since the sand is going to get wet anyways in the refining process, no special care is needed in its delivery.
But…
Does make me curious to wonder what was used before covered hoppers came into fruition. Boxcars perhaps? Ive seen these used to haul grain. It was just poured right in like it was a covered hopper of sorts.
Ofcourse, in those times as well, ‘open’ hoppers and gondolas were your primary aggregate haulers.
But yes, in addition to weight, I would think the handling of sand would be significanlty different if wet compared to dry.
IDK, in the picture above, maybe sand is dense enough that water would not seep down and contaminate the entire load? Maybe just the first few feet on top. I’d think wet sand would not flow well through the bays, but maybe all of it doesn’t get that wet during transport, as long as its loaded dry enough to flow, it can still be handled well.
Again, the pic is a surprise to me. I thought sand was transported in short covered hoppers in the modern day. I stand corrected.
Edit: The pic is not clear, but maybe the cars are not hoppers but ex-coal gondolas downgraded for sand service. A solid floor requiring a rotary dumper?
Atlanta Sand & Supply Company sells 3 different types of sand, constgruction, industrial and golf course sand. They have three locations around the Atlanta metropolin area.
