Santa Fe Yellow/Blue Bonnet
My favorite locomotives are the Santa Fe frieght engines with the blue body, yellow cab and yellow “Santa Fe” on the sides. I can’t seem to find pictures of this paint scheme whether I search “yellow bonnet” or “blue bonnet.” What the magic keyword? Thank you.
Try “freightbonnet” or “bluebonnet”. Leave out the space.
Try “modern ATSF [or Santa Fe] freight scheme” – ‘bluebonnet’ and ‘yellowbonnet’ are just railfan slang, not really different from ‘vomit bonnet’ [:)] (And as rcdrye noted, the color names, like ‘warbonnet’, don’t usually have a space … but I wouldn’t think that would trip up properly-programmed photo search engines.)
As I recall, the ‘revived’ blue and yellow scheme is from the Eighties (with the supergraphic-like “Santa Fe” in yellow) and was to distinguish freight power from the faster locomotives with the new-style warbonnet red and silver. If you search photo sites for ATSF freight engines by date range, you should come across pictures in fairly short order…
(I also cheated and typed this into Google, with what appear to be a great number of ‘desired’ results… add specific locomotive types for a more specific return.)
Not too sure about what “revived” is getting at. The first yellow warbonnet painted unit was in April 1972.
Ed in Kentucky
They might be thinking of the blue and yellow freight scheme used on the covered wagons.
I confess I sorta thought a ‘bluebonnet’ or ‘yellowbonnet’ was explicitly referring to an F-unit scheme.
What I remember from reading Trains was that a blue-and-yellow scheme was revived in (or by) the early Eighties – say by about 1983 – to allow distinguishing fast trains in the ‘warbonnet passenger’ colors from regular trains. I assumed this was obviously before SLSF reared its head, and it is or was the scheme with the very large yellow “Santa Fe” on the hood sides.
That might well have been started earlier, and I haven’t gone back to see when or if the Cleburne CF-7 program adopted it. Ed might do that. The question is then why the OP said he had such trouble finding pictures of ‘bluebonnets’ or ‘yellowbonnets’ in an image search – and he hasn’t to my knowledge said whether removing the space in the names produced more hits for him.
Think these are the definitions.
“Yellowbonnet” means the standard SFe scheme starting in 1972. Billions of pics of units in that scheme, since all their new units came like that until … dunno when.
The term “bluebonnet” originally just referred to a scheme used on some rebuilt (?) F-units. Don’t think there was ever such a thing as a bluebonnet SD45-2 or C30-7 or whatever.
The pre-1972 freight scheme wasn’t any sort of bonnet, of course. Someone decided SFe units should all look like they had hit a tank truck full of yellow paint, and fans naturally started calling the result “yellowbonnet”.
From 1960 to the middle of 1972, ATSF hood units and switchers were painted in a solid dark blue with the ends of the locos painted yellow. There was a yellow pinstripe at the top of the loco sides, with “Santa Fe” in large Cooper font on the sides of the road switchers, and “SANTA FE” in a smaller Roman font used on the yard switchers (SWs, Alcos, etc). This is known by railfans as the “Bookends” scheme.
In the spring of 1972 the “Yellow Warbonnet” scheme on road units came out, with the same pattern as the red/silver passenger units, but with yellow replacing red and dark blue replacing silver (same Large Santa Fe lettering on the sides). It came out at the “suggestion” of the FRA as having trains being more “visible” at grade crossings. The “yellowbonnet” lasted up to the BNSF merger.
The return of the red/silver “warbonnet”…officially called the “Super Fleet” paint scheme… began in 1989 when a pair of former FP45s were painted in the same red/silver colors as when they were acquired in 1968 for passenger service - but with the large Santa Fe lettering in red. Apparently SF management was impressed with the reborn colors to have their new wide-nose locomotives painted in the same color scheme, al the way up to the BNSF merger.
Other than the “Super Fleet” monicker, SF never had an offficial name for its various color schemes.
I typed in “santa fe blue and yellow locomotive” and still got mixed results. Sometimes I see a yellow F-unit.
Santa Fe repainted some red warbonnet F units into yellowbonnets and bluebonnets after 1971 when Santa Fe passenger service ended. The yellow and the blue took the place of the red in the warbonnet scheme. Several yellowbonnets were leased by Amtrak and were used on Amtrak’s version of the Texas Chief. The bluebonnets were used in freight service; I have seen pictures of them in local service in Kansas and in Texas.
All were eventually converted to CF7s, except an A & B (347?) that went to Albaquerque for preservation. I believe the A unit was a yellowbonnet. The historic collection was transferred to the California Railroad Museum, where the F7s were repainted into the red warbonnet scheme.
No reason to post the same photo in two different threads on the same day.
I can never see to many pictures of these locomotives. :slight_smile:
I agree with the yellow bonnet favor. Personally I think this is the best ATSF paint scheme right here. Warbonnet is overrated :slightly_smiling_face:
I agree. I liked the “book ends” scheme on freight units. The blue/yellow freight warbonnet scheme, to me, has too much yellow.
Jeff
So beautiful . . .
I seem to recall seeing photos of what was called a “superbonnet” or an extended version of the bonnet scheme. Seems that they were on some of the early EMD “E” units.Was there such a thing?
Addressed here:
An intermediately ‘long’ scheme was used of the FP45s.
and in blue and yellow later, and on the U30CGs as well, as seen here:
Many thanks for your reply, sir. Both videos were great. Watched the first one several times just to hear the sound of the unit. The second video was very good with a lot of info.
Gregory
