Would like to build a working sawmill for our garden railroad. How do you find the 1968 article by Jack work? Basically want to have the logs go back and forth with the saw blade spinning.
Sugermc,
[#welcome] To The Forums.
Suggestion: Give Kalmbach CS (Customer Service) a call and ask if they have the two issues, I believe there are two, June/July or if they have a PDF to send You.
https://secure.kalmbach.com/customer/Help.aspx?siteID=29&pubCode=HBS
Good Luck! [:D]
Frank
The articles you’re looking for are June and July 1968. If you’ve signed up for MR’s All-Access Archive, you can find those articles here:
I dont believe I can access items from the archives, as no longer have a subscription. I am mostly looking to see how the log-carriage system works, so I can build it. I just want the carriage to go back ad forth and cannot figure out what type of motor or electronic gizmo to use. Any help would be greatly appreciated Thanks
Then you can buy the back issues from Customer Service. Call them at 800-533-6644, 8:30 a.m.-4:30 p.m. Central time Monday-Friday.
