Scale recommendations for aircraft over an HO layout?
Hi everyone:
I just purchased a 1/87th model of a Douglas C-47 (DC-3 with bigger side door). I thought that it would look great hanging over my yet to be HO layout. However, once I got my hands on the kit I soon realized that it looks huge even though it is to scale. I had not taken into account the forced perspective that is required to make an airplane look like it is high in the sky.
My question is what scale(s) would you suggest would work better to give the desired forced perspective? There are lots of DC-3/C-47 kits and models available in smaller scales. Everything from 1/100 to 1/600. What do you recommend?
I should mention that the train room only has a 7 ft ceiling so I am limited in terms of how high I can hang the plane in the air.
Thanks
Dave
This old aircraft type would recommend the smallest possible size, and hang it about three inches below the ceiling. The object is to force perspective, and not have the featherless bird detract from the ground-level railroad and its surroundings.
Consider that the FAA would like pilots to remain at least 500 feet above the terrain unless descending for a landing or climbing out on takeoff. In HO scale, that means five feet nine inches above the hilltops - pretty hard to do with a seven foot ceiling unless your tracks are at floor level.
In all honesty, I am not a big fan of hanging aircraft models over a layout. Aircraft move, rather quickly. Unless you’re modeling a hovering helicopter or the Goodyear Blimp, it wouldn’t just stay there. And even the helicopter and blimp move over time.
Chuck (Retired USAF maintenance tech modeling Central Japan in September, 1964)
Hi Chuck:
Thanks for your recommendations. The question is now moot because I just found a 1:250 DC-3 in Canadian Pacific livery for a reasonable price, and I figured it was now or never. I’d have been ticked if I let it go.
I understand your point about not liking aircraft hanging still in the sky but that is something I can live with. I think we all have things that we don’t quite agree with in modeling. I will replace the props with clear styrene discs to simulate running engines like I think Mike Lehman does. As for altitude, I’ll just have to say they are “on approach”.
The reason I wanted a DC-3 was because I flew in a couple of them many years ago in Sweden compliments of the Swedish Air Force. The first one was polished like good silver. The second one looked like it had been in the crapper for several years. The crew joked that it was on its way to the scrap yard as soon as our flight was done![(-D][(-D] By the way, I experienced the worst rough weather ride I had ever had in the shiney DC-3. We ran into a storm front (I’m pretty sure the pilot did it deliberately), and we dropped far enough and fast enough that we rose out of our seats and the seatbelts, which were not in use, stood up on their own for a couple of seconds. We teenaged Air Cadets laughed our heads off! That was only 44 years ago.
Dave
I currently have a 188 Electra dangling over my layout that is in 1:144 scale. It works well because the smaller scale adds to the illusion of altitude. I imagine that somewhere well outside the realm of my layout there is an airport guiding my Electra to the tarmack.
:slight_smile:
Mark H
Dave,
There’s a discussion of several of your questions and lots more in a thread I did on my aircraft a couple of years ago.
http://cs.trains.com/mrr/f/88/t/228279.aspx?page=1
One of my favorite builds was the little Osborne DHC-2 Beaver, an aircraft I’vge always wanted to own…but I could only afford a layout.[(-D]
Here’s a pic of it towing a glider, also in HO.
Depends on the scale of the antiaircraft gun.[:-^]
20 mm works quite well…oops…scale, BB’s maybe. [:-^]
[(-D]
Mark H
I´d suggest 88mm (remember the infamous 8-8 FLAK gun?) [swg]
On the serious side, I can follow Chucks arguments against hanging anything above the layout. There is something “artificial” about any objects, be it on land, on sea or in the air, which are in a state a a “frozen” motion. I even try to avoid figures with a frozen motion!
Sadly a very good suggestion.
Cheers, the Bear.[swg]
Or…this one!!![:-^]
Take Care! [:D]
Frank
I’m partial to the slow-moving blimp, preferably in U.S. Navy livery, to represent the WWII through the 1950’s time period. My dad worked for Goodyear, and was involved in building the control gondolas until he retired in 1973.
Or maybe a balloon.
ROCO makes a 1/87 8.8 cm FlAK 36/37…
Tom,
Hmmm, am I remembering right that Walthers or someone else offered a blimp model at one time? They are awesome to see. Always had a soft spot for the blimps (seen the Goodyear a couple of times passing in transit) and their rigid big cousins, the zeppelins. Waaaay too big for most layouts, though.
Mike:
Glencoe Models has a U.S. Navy K-class blimp in 1/330 scale. It’s about 11" long. I believe K-ships were the most common of the Navy’s patrol blimps. Don’t know whether the kit is still available. The box says Copyright 2006. I haven’t built mine yet, so I can’t say anything about the quality of the kit.
I think you know the terminology, but maybe others don’t. Lighter-than-air craft that are long and narrow, and can be steered, are referred to as airships or dirigibles, although those terms are not usually applied to blimps as far as I know. Zeppelins were invented by Count Zeppelin, and were large enough to require a metal frame to maintain their shape. That’s usually what we mean when we talk about airships or dirigibles. Blimps have no internal frame because they are smaller and don’t need one to maintain their shape. During WWI, Britain used unframed small diriigibles and called them “Limps” because of their flexibility. The most common type of British Limp was the B-Limp. Thus the name Blimp.
Modern blimps are usually in the 200-300 foot length range. The really big airships like the Hindenberg, or the US. Navy’s Akron and Macon, were in the 800 foot range. The fire-related crash of the hydrogen-filled Hindenberg, and the structural failures of the helium-filled Akron and Macon, meant that the age of the really big airships ended in the 1930’s. But the U.S. Navy used blimps throughout WWII and well into the 1950s. The last variant was the ZPG-3-W, which carried a radar screen inside its balloon. It was retired around 1959 or 1960. We used to see blimps flying around Akron a lot when I was growing up in the 1950’s. Saw two flying around Akron when I was there about 2 weeks ago, in fact.
Also, there are, or have been, models of the Graf Zeppelin, Hindenberg, Akron,
Tom:
I don’t mind when people go off topic, especially when the information is interesting like yours is.
I’m modeling the late 50s so blimps might be a bit of a stretch, not to suggest that I haven’t stretched a few other things that aren’t exactly right for the time. The 1:250 DC-3 will be a bit of a stretch because it has the CP Pacman livery but that I can live with. I suppose I could repaint it if I could find the right decals.
Bear and Ulrich:
I’m not planning on modeling anti-aircraft guns on the layout, but I do have a great substitute! My son just gave me a sling shot for chasing the blackbirds and squirrels away from our bird feeder. Don’t worry, we are using dried chick peas as amunition, and we don’t pull it back all the way. The chick peas are a bit hard to shoot straight because of the irregularities in the surface but they get the message across just fine.
There Tom, hows that for [#offtopic]?
Dave
Mike:
How did you make the disc that models the moving propeller?
Thanks
Dave
Still [#offtopic], but on with the thread…
During my career with the USAF I worked on both the Beaver and the Gooney Bird - in fact, one of the gooney birds was gussied up to carry Lady Bird Johnson around Texas. (She only used it once!) Neither type was designed for ease of maintenance, so neither makes it to my list of favorites.
As for AA weapons, I’m partial to the quad mount M2s on a half track, and to the twin Bofors on a tank chassis. My father commanded the 142 AAAW Bn, which had both at the time (1948-1952.) But, if you want serious bang for the buck, you can’t beat twin-mounted 5"/38’s. Proximity fuses, you know, and effective anti-ship weapons as well. (Check Battle Damage, IJN Kirishima, and the Battle off Samar.)
The M1A1 main gun is NOT an effective AA weapon. Insufficient elevation.
Chuck (Retired MSgt modeling Central Japan in September, 1964)
I’m kind of curious what threat the CP DC-3 poses, that requires the use of AA in the first place. Is Canada planning to invade? Just curious.
Tom:
Maybe if some terrorist cuts the string holding the DC-3 over the layout![swg][(-D][(-D][:o)]
I’m glad you are all taking this so seriously![swg]
Dave
While I don’t normally have an aircraft over the layout, I usually attribute aerial photos of my layout (to illustrate track arrangement, structure placement, etc.) to Secord Air Services. A fisherman on the Maitland River managed to snap this shot of Barney Secord (owner and sole pilot of SAS) flying under the Erie Northshore’s bridge. (Must’ve been a pretty fast shutter speed, judging from the look of that prop.)
While one wheel of the landing gear appears to be contacting the water, Barney somehow avoided crashing on this particular occasion, but there have been other “incidents”. [swg]
